Question about Ryobi EJ-600 Jigsaw 600 Watt - RYBEJ600
Jig saw blade js500
Blade holder
Extracting broken blade not sticking out of blade holder
Spray with WD 40 and insert Needle nosed pliers to grab and pull it.
Nov 30, 2013 | Ryobi Js550l Jig Saws
The blade is stuck in the jigsaw, is there a way to get it out? Usually you push down this little lever and it releases it, but that is not working.
Spray some WD40 or equivalent into the blade holder, leave for a couple of minutes, then pull down on the blade with a pliers while pushing on the lever.
May 09, 2011 | Black & Decker Black Decker 18v Bare...
How do i remove the blade on a black and decker U255S Jigsaw
either on the left or right side of the blade holder there will be a little lever to pull that will release the blade, pull on the blade at the same time you pull on this release
Jan 17, 2011 | Black & Decker Black Decker Orbital...
How do you put a blade in a hitachi cj110mv jigsaw
on the front of the saw where the blade is there is going to be a little lever you pull while at the same time push the blade in the blade holder
Jan 16, 2011 | Hitachi CJ110MV D Handle Jigsaw
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
I don't know how to get the blade to stay in.
You have a set screw on the side of the blade holder, usually an allen head, some jig saws have a clamp through the top, a screwdriver down through the top will grab it. Check it out.
Nov 15, 2010 | Makita Jigsaw Blade
How do i change the blade
Hello. where the blade enters the blade holder there is a screw. Unscrew it, turn counterclockwise, remove the screw and then remove the blade. Reinstall the new one and replace the screw. Joe
May 08, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
How do I change the blade on a Black & Decker JS500 jig saw?
Go to Dewaltservicenet.com and type in your model number and you can download the instruction manual for this tool with detailed instructions on how to change the blade. It is 8 pages long.
Oct 03, 2009 | Black & Decker Scroll Jig Saw Blade
Cannot get the blade in woolworth own make laser jig saw
If you look at the front of the tool down where the blade goes, do you see two allen/hex screws? If so these need to be loosened, a blade inserted up into the holder and the screws re-tightened to hold it there.
Jun 18, 2009 | Electric Jig Saw W/laser Guide
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
Ryobi EJ-600 Jigsaw 600 Watt - RYBEJ600 Logo
51 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
