Through the 3.5mm headphone jack from your headphones, its a pretty small hole usually to the front of the tv set, being so small you may have to look for it. If it is wireless you will need to connect the main headphone system to the back of your TV (audio in jack) then ensure system is powered on and headphones are charged.
You will need to remove the broken piece. Power down the computer and unplug it. The only suggestion I would have is see if you get get to the jack from inside the computer and push out the broken piece with a paper clip.
u will need to get ur headphone jack replaced as it it the only sound out u have, secondly, u can go to anyone who repairs motherboard and get it done. its not neccesary only from the company because u will be charged more there, but mind u they give warranty for their work. so ur choice
I have the same problem as well. you just have to take the headphones out, and not put them in all the way. just put them in partway, wait until you can hear out of both.
Sound not coming out of one side of the headphone is an indication of connection failure, so that means you have to see where its 'broken' from, either inside the headphone on on the wire somewhere. Usually it happens at the jack, especially if you use an ipod as it tends to get moved alot in pockets, etc..
If this is the case, you could try to cut the wire from where you suspect its broken, and get a 3.5mm (or whatever the original size is) replacement (Do-it-yourself) jack from Radio shack or electronics store.
THen you would have to cut the wire, strip the the rubber coating off, and then if applicable, carefully strip the very thin layer of further insulation thats on the wire it self. Otherwise you would directly connect the cables to the prongs/connections located on the replacement jack. And depending on the jack you would screw it in place or soldier it with soldier and soldiering gun.
If its broken in the headphone or at the headphone, thats much harder to do as you would have to open the head/earphone case and soldier it that way and get it back together in one piece.
Next time don't buy bose headphones and by something cheaper, bose isn't that great, skullcandy is pretty good too. Sennheiser is the best though in my opinion. albieit its expensive too..
First off - Is there any warranty warranty left? Otherwise what most likely happened is the headphone jack connector broke a terminal. If it is a model with a screen, the headphone jack is a separate piece off the motherboard. It's a cheap part off of ebay, just find someone with nimble hands to reconnect the ribbon cable inside.
Well I had The Same Problem. I Thought it was the headphones and it wasnt. I ended up ripping the new headphones.
I Was really mad i Opened up the whole Player and Disconnected Everywhere and found that it was the earphone jack. the soldier it had was very cheap so it had no contact whatsoever. I connected it by bending the metal and closed the player back up and till today it now works.
I think it is your earphone jack. sansas have very cheap earpphone jack soldier or something.
I encourage you to open up the player and check the soldier. I you want contact me and ill post a video on how i did it. Hope this works.
The Sansas Earphone Jack soldier is very cheap try bending it or placing something extra to hold the jacks connection to the player. when closed its not niticeable, no need for soldiering. Try it. Contact me if you want a video of what i did. hope this works.
