Question about Saws
Ryobi js500qeo jig saw
Blade holder
  • 12 Answers
SOURCE: Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Posted on Feb 25, 2009
joboo1
  • 257 Answers
SOURCE: Problems with Bosch T101BR 4 Inch 10 Tooth Jig Saw Blades
Hi, The reason for a down cutting blade is to see your cut on the finished side of laminates ( which include veneers, plywoods, plastics, formica . When using an upcutting blade on laminates the smooth cut is on the bottom, which you can not see till you are done and turn the work over. Reversing the teeth allows that smooth cut to be on the top. This is usually done on smooth flat surfaces as you have found out and does not work with orbital or tight scrolls. As far as the pushing or pulling, smooth cuts in laminates require the saw doing the work at a speed that allows the teeth to cut and remove material with biting. So if you are biting, (This is a much slower process than pushing your jigsaw through regular wood) check that you are not pushing too hard and that your blade is still sharp. Good Luck to you, this should Fixya!
Posted on Mar 08, 2009
  • 3 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: change blade 1587 Bosch avs
are you using the "T" shank blades and also are you loosening the spindle enough to allow the blade to turn, sometimes you have to push up a little to turn it and also pull away from the roller guide. Let me know and also there is a TINY spring in the top of the spindle that has a nasty habit of breaking and winding around itself not allowing proper operation.
Posted on Oct 10, 2009
FixYaSteve
  • 57 Answers
SOURCE: How do I change the blade on a Bosch pst 54E Jig
There's an exploded diagram of a similar model here. Don't let it confuse you though. I mention it, because it shows the clamp screw which hold the blade in place (35 on the diagram).
Unplug the saw before you change the blade.
In the handle directly over the blade there is a hole with a clamp screw at the bottom. Use a long thin blade screw driver to loosen the clamp screw.
Once the clamp screw is loosened, twist the blade about 90 deg and you should be able to pull it out (don't cut yourself, by accident)
Put the new blade in with the same orientation and twist so the blades are facing the front of the saw.
Tighten up the clamp screw and you're good to go.
Be careful not to tip your saw over while the screw is loose. If it falls out and you lose it they're a bit of a nuisance to come by.
Posted on Jun 14, 2010
What type of blade do I need for a jigsaw ryobi js500qeo
Any type of jig saw blade will work, the are universal....
Feb 25, 2015 | Ryobi Saws
How do I change blade on Ryobi compact saw please
Which exact saw are you talking about? Jig saw, circular saw, plug-in, or battery? It does make a difference, you know...
Jan 07, 2015 | Ryobi Garden
Extracting broken blade not sticking out of blade holder
Spray with WD 40 and insert Needle nosed pliers to grab and pull it.
Nov 30, 2013 | Ryobi Js550l Jig Saws
How do you put a blade in a hitachi cj110mv jigsaw
on the front of the saw where the blade is there is going to be a little lever you pull while at the same time push the blade in the blade holder
Jan 16, 2011 | Hitachi CJ110MV D Handle Jigsaw
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
Trying to change blade in Ryobi P520 Jigsaw
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
Nov 02, 2010 | Ryobi 18 V Orbital Jig Saw P520
How do i change the blade
Hello. where the blade enters the blade holder there is a screw. Unscrew it, turn counterclockwise, remove the screw and then remove the blade. Reinstall the new one and replace the screw. Joe
May 08, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
I am trying to replace the blade in my scroll saw because the other blade broke and I can't seem to figure it out. Any suggestions?
Manking an assumption that yours looks like this one below?
If so, you'll need to flip up the yellow catch to release the jig blade. Sometimes they get a bit stiff, so wearing gloves try and waggle the blade free. There is normally a tensioner at the back that guides the jig blade (like a roller) that can also be loostened off to get the blade out
Install is reverse of removal
If this helps, pls leave feedback, if not let me know and I'll try and help some more!
Jan 27, 2010 | Ryobi Saws
Cannot get the blade in woolworth own make laser jig saw
If you look at the front of the tool down where the blade goes, do you see two allen/hex screws? If so these need to be loosened, a blade inserted up into the holder and the screws re-tightened to hold it there.
Jun 18, 2009 | Electric Jig Saw W/laser Guide
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
Saws Logo
121 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
