Question about Hotpoint Dryers
My Hotpoint CTD00P tumble dryer is not getting hot why could this be?
If it's electric heat then more than likely it's the heating element burned out. If it's gas heat probably the gas solenoid is bad.
Posted on Feb 08, 2014
2 Suggested Answers
TAGTEL
  • 16 Answers
SOURCE: TUMBLE DRYER DOES NOT GET HOT
Hi, - The first thing to do is UNPLUG THE DRYER! Then remove the heater cover situated on the back panel. It is the curvey shaped panel.
Remove all the screws and the panel may be slightly stuck - just prise it off.
Next - there are 2 small screws holding the heater and thermostats assy onto the back panel. - Remove these to free the assy from the back panel. Be careful not to touch the elements as they break easily.
The problem is probably the Thermostats.
The one on the left is the Overheat Thermostat - You will notice a small hole in the centre of the thermostat. Take a Pin and push it firmly into the hole and you may hear the Stat "click". That has re-set the stat.
Re-assemble the Dryer being careful with the elements.
Now - Why has it tripped? If it has overheated it is because of one or all of the following.
1. The Condenser unit is getting blocked - Remove and clean under running water like a hosepipe or tap.
2. The door filter is not being cleaned
3. Sometimes opening the door to check if the clothes are dry and then not allowing the dryer to cool down can cause the problem. Always allow it to go through the cool down process.
Hope this helps. The Heater and the Thermostats are available as Spares - Terry
Posted on Mar 15, 2008
No power to myctd80 dryer
if i remember rite ctd40 has three stats over heater 1 has pin hole in top push needle in hole to reset it and take needle out then try ive done this on sum
Apr 01, 2013 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
Timer counts down too quickly
Possible there is fault in the timer unit . check for loose connections or loose joints to the unit, if not this needs a replacement.
Jan 12, 2013 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
Faulty control board hotpoint ctd85
You can remove the panel and check for fault in the connectors and the line to the display, use a hair dryer to warm and dispel any moisture on the board and panel. If there is no result then the panel has to be replaced.
To remove click : control panel
Jul 26, 2012 | Hotpoint Belt for CTD00P, CTD40, CTD80,...
How to change belt on Hotpoint CTD00P Tumble dryer
There should be a belt tenstioner and small pulley that is spring loaded if there is not a belt on it the pulley is in the bottom of the dryer.You have to place the tenstioner back in a slot or holder and then the pulley will keep the belt in place.
Apr 22, 2012 | Hotpoint Dryers
Hotpoint AQCF852BU Condenser Tumble Dryer
how do i change the belt on my hotpoint aquariue ctd00 model ctd00p
Oct 22, 2010 | Dryers
I have hotpoint consdenser dryer model ctd00p - not drying clothe
if the water tank is empty you probably need a new thermostats .
Feb 11, 2010 | Dryers
Dryers Logo
56 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Dan Webster
Dan Webster
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
