Question about HP 5187-7583 Silver Multimedia Keyboard With Media Player Controls
Keyboard button controls
How to add them
How can I type Japanese o keybord?
Hai ! This is possible : )
Type in Chinese, Japanese, and other character-based languages
To type text on your computer in character-based languages, such as Chinese and Japanese, follow these steps:
[Source: http://windows.microsoft.com/en-us/windows-vista/Type-in-Chinese-Japanese-and-other-character-based-languages]
  1. Add the language as an input language. If you want to use an input method editor (IME), make sure you select it when you add the input language. For more information, see Add an input language.
    You can edit documents in multiple languages by changing the language (the input language) in which you type. Input languages are included with Windows, but you need to add them to your list of languages before you can use them.
    1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
    2. Click the Keyboards and Languages tab, and then click Change keyboards.
    3. Under Installed services, click Add.
    4. Double-click the language you want to add, double-click the text services you want to add, select the text services options you want to add, and then click OK.
  1. Change your input language to the language you installed. For more information, see Change your input language.
The input language is a setting in Windows that controls the language you use to type information on your computer. Before you can change an input language, you need to add that language to Windows. For more information, see Add an input language.
To change the input language
Click the Input language button on the Language bar, and then click the input language you want to use.
93d5c617-b1ec-4138-a1ff-973e71de80fe.pngLanguage bar gl_ico.png Note
If you don't see the Language bar, right-click the taskbar, point to Toolbars, and then click Language bar.
  1. Change your keyboard layout to the desired layout. For more information, see Change your keyboard layout.
You can customize your keyboard for a specific language or format by changing the keyboard layout. The layout controls which characters appear on the screen when you press the keys on your keyboard. Some input languages have several keyboard layouts; others have only one. For example, you can change your keyboard layout from the English QWERTY format to the English Dvorak format. After you change the layout, the characters on your screen might not correspond to the characters on your keyboard keys.
Before you can change the keyboard layout, you must add the input language and keyboard layout that you want to use to Windows. For more information, see Add an input language.
Hide all expcol_imgs.png To change the keyboard layout
  1. On the Language bar, click the Input language button, and then select an input language.
  2. Click the Keyboard layout button, and then select a keyboard layout.
gl_ico.png Note
expcol_imgs.png To change the keyboard layout on the Welcome screen
On the Welcome screen, click the Keyboard layout button 0c181420-8a93-48b6-82b1-b2dc25fc01b5.png, and then select a keyboard layout.
TIP:
After you are done you can switch between Japanese and English very easily by manually pressing the on screen buttons or using keyboard commands like SHIFT+ALT to switch between Japanese (???) and the Alphabet.
May 04, 2011 | Compaq Keyboard
I can't get the backslash
Please change your keyboard layout to US
1. On the Language bar at the bottom of your screen (next to the clock), click the Input language button, and then select an input language.
Depending upon your Operating system follow the following steps to change the languages of your keyboard.
Instructions for Windows Vista
  1. Click Start and then Control Panel
  2. In Control Panel, if you are in Classic View, click on Control Panel Home (top left corner)
  3. Open Clock, Language, and Region
  4. Click on Regional and Language Options.
  5. Click the Keyboards and Languages tab and then click Change keyboards.
  6. Under Installed services, click Add.
  7. In the Add Input Language dialog box, select the keyboard layout you would like to add from the list available and click OK.
  8. The keyboard layout you added will be included in the list. To set the new layout as your default, select it from the list. Click OK to save your changes
  9. You can switch between different input languages (= keyboard languages) by clicking on the Language Bar button or by pressing the Alt + Shift keys
Instructions for Windows XP
  2. In Control Panel, if you are in Category View, click on Switch to Classic View (top left corner)
  3. Open Regional and Language Options.
  4. Click on the Languages tab.
  5. Under Text services and input languages, click on the Details button.
  7. In the Add Input Language dialog box, choose the input language and keyboard layout or Input Method Editor (IME) you want to add.
  8. Click OK twice. You should now see a language indicator in the System Tray (located at bottom right hand corner of the desktop by default). You can switch between different input languages (= keyboard languages) by pressing the Alt + Shift keys
Nov 18, 2010 | Computers & Internet
Model SK-8315. Keys pressed do not respond to the letter required.
1) Install the correct driver for your keyboard.
2)
For Windows XP: Control Panel -> Regional and Language Options -> Languages tab -> Details button (which opens Text Services and Input Languages dialog box) -> Installed Services -> Add button -> Keyboard layout/IME -> (There you choose your keyboard layout)
For Windows Vista: Control Panel -> Regional and Language Options -> Keyboards and Languages tab -> Change keyboards button General tab
Oct 18, 2010 | Dell 0Y3740 Keyboard
Some of the keys not working such as the pound sign# and the @ sign i have to use the number 2 to activate the @ sign
Your PC Language settings are incorrect
How to change keyboard language in Windows
Jul 02, 2010 | Dell 0Y3740 Keyboard
I use a Logitech keyboard with Windows Vista, Home Basic operating system. The symbols " and @ have somehow changed keys on the keyboard. My problem is how to re-assign them to their original...
Go to Control Panel -> KeyBoard -> Properties -> hardware -> Properties and uninstall the keyboard. The reinstall it. That should solve your problem.
Oct 22, 2009 | Logitech 967437-0403 Keyboard
How to get French keys back to English
Follow these instructions to change the keyboard :- Instructions for Windows Vista
If a language does not appear in the Input language list, the fonts for that language might not be installed. If that is the case, follow the instructions below.
Add language support
  3. Open Regional and Language Options in Control Panel.
  5. Under Supplemental language support, select the check box beside the applicable language collection
  6. Click OK or Apply. You will prompted to insert the Windows CD-ROM or point to a network location where the files are located. After the files are installed, you must restart your computer.
Sep 19, 2009 | Acer NSK8458AN Keyboard
When I type some letter/keys do not register
Hi !!
Thank you for choosing Fixya.com
Cause: This could be because of, keyboard layout you have selected in the control panel is not appropriate. Change the layout back to "US" or "UK"
& it will help !!
Regard's
Anurag Shukla
Sep 07, 2009 | Dell 0Y3740 Keyboard
Keys on keyboard typing wrong characters
Apr 10, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Dell cordless keyboard keys deliver wrong alphabet
Follow these steps to make sure your keyboard is in the right language settings
Dec 27, 2008 | Dell iTOUCH Cordless KeyBoard &Mouse Kit...
On the Acer One laptop, how do I select UK English keyboard Not US?
Nov 11, 2008 | Acer Computers & Internet
HP 5187-7583 Silver Multimedia Keyboard With Media Player Controls Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
