Question about Compex WavePort WL11 Wireless Adapter
Compex waveport driver - Compex WavePort WL11 Wireless Adapter
Waiting for rs
I was having the same problem just a moment ago but I got it to start working again. Here is how I got it to work. When you set your compex to charge it will charge for a few seconds then show the "check waiting for rs". When that, happen push the power button off and on, once that is do it well start to charge again but just for a few seconds long than the first. You will get that massage again "check waiting for rs". All you have to do is keep turning off and on the compex when you see the rs massage. You should notice the compex charging longer now. Once you hit a charge time of at least 21 to 23 seconds it should continue with no problems. I hope this method works out for you.
Dec 21, 2013 | Compex Sport Elite Muscle Stimulator
How can I reset Compex SGX 3226 to default (factory) settings?
Your device is a bit light on support, a brief user manual can be found here: http://www.manualslib.com/manual/223934/Compex-Sgx3226.html#manual Usually there is a tiny recessed RESET button on the device, push and hold for 30 seconds or so will return to defaults.
Apr 02, 2013 | Compex Computers & Internet
I need compex RE100ATX/wol lan card driver for win 2003
This site has the driver.
http://www.nodevice.com/driver/RE100ATX_WOL/get33761.html
Type in the CAPCHA verification code then click the blue download button
Jul 07, 2010 | Compex (RE100ATX/WOL) Network Adapter
Picked up a Compex NetPassage 27G at a yard sale and cant access it. Does it have a default username and password?
Hi
start by trying these:
Default IP for all Compex's Routers/ APs/ Client Adapters: 192.168.168.1 Default IP for all Compex's Modems: 192.168.1.1 Default IP for all Compex's Switches: 192.168.100.128 Default Password for all Compex's products: Password Default User ID for Compex's modem: Admin
alternatively most router will have a reset button that's usually behind a little hole in the back or at the bottom of the unit. inspect the device carefully and introduce something sharp (that won't break) through that hole while the unit is powered and press for 30 to 60 seconds, this is usually how devices are brought back to factory defaults. if this does not work it's like the device is defective and you may want to get your money back!
hope that helps!
Apr 19, 2010 | Compex NetPassage 27G Wireless Router...
I need driver Compex iWavePort WLP54G Wireless Adapter for OS windows7 thanks...
Compex iWavePort WLP54G Wireless Adapter does not currently have a official driver for Window 7
Jan 24, 2010 | Compex iWavePort WLP54G (E81361) Wireless...
I don't have drivers for Link Port ue202-b
http://www.nodevice.com/driver/UE202-B/get43619.html
Enter the verification code, and click download.
Jan 13, 2010 | Compex LinkPort UE202-B (LINKPORT/UE202-B)...
I need drivers for compex linkport ue202-b for winxp
go to the official website of ur hardware and download the driver.then run to ur computer.
Sep 12, 2009 | Compex LinkPort UE202-B (LINKPORT/UE202-B)...
Waveport wp11 wireless router. Is it usable. Its new
Did you also purchase the power-supply? If so, connect a network cable from your computer to one of the LAN ports, and then use your web-browser to connect to the device's built-in web-server, and see if you can connect and configure the router.
Jun 04, 2009 | Compex WavePort WP11
Adapter specs
hi..
i've also got one without DC adapter... and looking around. find this link here: http://www.corg.ru/products/Network%20equipment/Compex/TP1008C saying: Power Supply: External power adaptor input 220V-110V, output 7.5v/1A
hope it helps
Aug 07, 2008 | Compex MicroHub 8 Networking Hub
Compex WavePort WL11 Wireless Adapter Logo
Top Compex Computers & Internet Experts
Michael Galve
Michael Galve
Sandeep Kamat
Sandeep Kamat
Are you a Compex Computer and Internet Expert? Answer questions, earn points and help others
