Question about Sony Handycam Video Cameras
Hdd write protected
When the hdd formech atted an attech the system all process is clear but last stage open the dilogbox this drive is write protected. how to formate the my hdd
techbuster
  • 5081 Answers
SOURCE: write protected
couple of things you can try here, I will list them in order to try
Download one of the following registry tweaks to enable or disable writing to USB drives.
Enable USB Write
http://www.howtogeek.com/wp-content/...leUSBWrite.zip
Disable USB Write
Once you use the registry hack, you will have to reboot for the changes to take effect. One should also note that if you are using this trick, you should make sure that the users are not administrators on the computer, because they could easily change this setting back.
This works on Windows Vista as well.
This is my upload, so no need to worry
Format_Flash_Drive
RapidShare: Easy Filehosting
Registry
Warning If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. If uncomfortable with using Registry Editor, see if you can find someone who is comfortable and that you can Trust. Use Registry Editor at your own risk.
For XP Machines Only
Quote: 1) Click Start->Run.
2)Type regedit and hit enter.
4)Click on the plus sign next to HKEY_LOCAL_MACHINE
5)Click on the plus sign next to SYSTEM
6)Click on the plus sign next to CurrentControlSet
7)Click on the plus sign next to Control
8)Click on the plus sign next to StorageDevicePolicies
9)Write click on WriteProtect and click modify.
10)If the value data is 1 change it 0 and click ok.
11)Repeat steps 7 to 10 for ControlSet001 and ControlSet002 .
12)Close Registry editor and restart the computer.
If you don't find it in the registry, the best way is to create it yourself. Below is the procedure.
Start the Registry Editor
Go to the HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control key
If there is no key called StorageDevicePolicies, create it
You do this by right-clicking the HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control key, and selecting New > Key from the menu.
Select the StorageDevicePolicies key
From the menu select Edit > New > DWORD Value
Name the new value WriteProtect
Right-click the WriteProtect value and choose Modify
In the Value Data: box enter 1
Exit the registry editor, and restart your computer"To reverse, just delete the new WriteProtect value (or set the value to 0) and restart the computer."
Posted on Jul 03, 2009
puertobori
  • 7733 Answers
SOURCE: sir when i atteched pen
Search Google for MiniTool a freeware to format it.
Posted on Oct 06, 2010
SOURCE: my pen drive when
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Posted on Nov 19, 2010
bronk50
  • 27725 Answers
SOURCE: pen drive is not opening
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on Mar 27, 2011
SOURCE: pay pal isn't working at the last process step.
contact paypal customer service
Posted on May 30, 2012
This computer system, #hqhd3bs-595b is protected by apassword authentication system you can not access the data on this computer how i remove password
find dell bios password, hard drive password at biosremoval.com
note that bios passwords are different from hard drive password,
bios = unlock dell motherboard HDD = hard drive unlock
some computers may have up to 3 passwords being the last one windows passwords.
Oct 31, 2012 | Dell Inspiron 1545 Notebook
Tip
Why is the boot drive letter not C: after installing Windows XP on a blank...
The Windows setup process did not assign drive letter C: to the hard drive during the Windows XP/2000/NT installation process. WHY did this happen?
During the installation of Windows XP (2000 and NT use the same process) after a BLANK hard disk drive has been installed in the system, the setup process does not AUTOMATICALLY assign drive letter C: to the HDD. This can happen because an existing hard drive partition was not detected by setup and one of the following:
1. There is a Media Card Reader in the system
2. There is a Zip Drive in the system
3. There is a USB Flash Drive connected to the system
4. There is a USB Printer connected to the system that has a media card reader
5. There is an External Hard Drive connected to the system
If, any of these devices are in the system, setup will assign drive letter C: to one of these devices and then the hard disk drive (HDD) ends up with drive letter H or such. The boot drive letter in and of itself is not a big deal. Anyone with a multi-boot system like mine at home is familiar with non-C: boot drives and they per se cause no problems (You just have to know the drive letter of your boot drive).
To prevent this from happening, boot to your Windows CD and run the setup thru the creation and formatting of the hard drive. Power the system off manually, then restart the Windows installation. The partition you created on the last install will be detected and assigned drive letter C:
on Dec 03, 2009 | Computers & Internet
Bad sectors
Yes your hard drives electronics are failing. you need to replace your hard drive.
Jul 15, 2012 | Toshiba Satellite Computers & Internet
My Sandisk 'Wake up your phone' adapter & the micro one won't let me add music or anything else. It says that the disk is write-protected. Help?!
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 10, 2011 | SanDisk 2GB microSD Memory Card
I have a 1GB corsair SD flash card with photos; only 75% deleted and I get a write protection message. Its used in Lumix DMC-FZ20 and it shows no photos on card but the PC shows 25% full. How do I...
just format it and if you want your data then,
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of datarecovery). how:
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3,4)
After all data is secure, do the process of removing the micro SD password
Step Two:
4. If you are using Win Vista or Seven, double click the file cp006049.exe - selectextrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - selectdrive - Next - Create new or replace exiting configuration - Next - Hard drive - Next -Create new file system - Next - wait until the process is completed - Next - Finish.
Sep 16, 2011 | SanDisk 2GB microSD Memory Card
How can I format in Fat32 format this HDD
Open My Computer icon on the desktop. locate the hard disk you wish to format in FAT32. Make sure is not your main drive where windows was installed which is Drive C: Right click on the drive you want to format and select Format, a formatting window will pop out, there you see capacity which is the size of your hard drive,File system, and so on. Select the drop down menu under File system where we have NTFS and FAT32. Set it to FAT32. Under Format Options, Select Quick format and click Start. A warning message will pop out Click Ok to proceed. Wait a moment until the formatting is complete. Good luck.
Feb 03, 2011 | Western Digital Caviar SE WD800JD SATA...
Stereo
If your stereo is showing the protect display, it is an indication of a power shorting. This protection is to avoid serious circuit burnout and could be in the power output stages of the set. You will need to open and check for short in the output drives, the preoutput stages, the speakers or even the protection circuit amp.
It is important to address and check these sections with a votage check, elimination process too confirm the part. this may be a little tough and diffcult unles it shows easily on a continuity test. Helpful. Good day
May 31, 2010 | Kenwood Audio Players & Recorders
The virus protection on my PC is switched off. Can you pleased tell me how to turn it on?
hi firend
one way to resolve your problem u have remove your hard isk & attech with a good letest updated antivious pc scan your harddisk from the antiviros & put it back in your pc try to on it
if problem occers u need to reinstall window after install do not open d, e or any other drives then install antivours update it & do not open any drive from your pc scan all of your drive with a antivorus software then
Apr 22, 2008 | Computers & Internet
Write Protect ative. Disk don't permit writing or formating
What type of disk do you have? Provide with your system configuration. Company of your disk and size. Thanks! Anks
Mar 27, 2007 | Fuji (MAP3367NP) 36.7 GB Hard Drive
Video Cameras Logo
11 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
