Question about Nidec a80856-002 - Fan Intel A80856-002 F08g-12b2s1 05ac1 Dc12v
F08g-12b2s1 05ac1 desperately search the air flow capacity (in cubic-feet/min or liter/min) -to be used for another purpose than pc cooling - not sure if first "ask" was sent. Many thanks for help.
    Master:
  • 435 Answers
I'm not sure what you need to know. Do you have a mechanical problem or are you having trouble with a mathematics equation?
Posted on Apr 27, 2014
MT 600101 oil-less compressor, pdf manual. I specifically would like to know the scfm ratings at 40 and 90 psi.
the air flow from a compressor is determined by the capacity of the pumping system
with a piston type compressor it is the bore by the stroke
in a diaphragm type is it is the diaphragm dia by the stroke
that is the maximum cubic feet of air a minute produced
pressure is the resistance to flow so regardless of the pressure or restriction it will only produce that set air flow at that rpms
do not confuse the flow with pressure as it works like this the greater the restriction the greater the pressure in reserve but the less flow in cubic ft per minute through the restriction
for example a compressor producing 10 cubic feet per minute does that with not restriction but with no pressure
at 25% restriction to air flow the pressure in the tank will now rise to say 25 psi and the flow from the restriction will drop to 8 cubic feet per minute
at 50% restriction the compressor is still putting out 10 cubic feet of air per minute but the tank pressure has risen to 50 psi and the flow from the restriction has dropped to 4 cubic ft per minute
go to the extreme end and the compressor is still producing 10 cubic ft of air per minute , the restriction now allows 100 psi in the tank but the low from the restriction has been reduced to 2 cubic ft per minute
the simple equation is pressure = flow X resistance
Jun 24, 2017 | Air Tools & Compressors
What is capacity in cubic foot?
  • How to Calculate the Capacity of a Washer Tub - About.com Home laundry.about.com > ... > Selecting a Clothes Washer 2016-04-14 · Video embedded · How to calculate the capacity of a washer tub ... your washing machine ... listed in cubic feet. A regular capacity machine is between 3.1 ...
  • Washer buying guide - CNET www.cnet.com > Appliances > Washing Machines 2013-09-12 · Washer buying guide. ... They have a smaller wash capacity, averaging at 1.5 cubic feet, ... What washing machine capacity do I need?
  • Washing machine capacity in cubic feet ... - Yahoo Answers https://answers.yahoo.com/question/index?qid=20121014130558AA2ph3V
    • RESOLVED
    • 3 POSTS
    • 2 TOTAL ANSWERS
    2012-10-14 · Washing machine capacity in cubic feet what does this mean? ... What does DOE stand for in regards to a washing machine's cubic feet?
  • Washing Maching Buying Guide - Warners Stellian ... www.warnersstellian.com/washer-buying-guide washer buying guide: ... Most conventional top load washers range between 3.2 and 3.5 cubic feet. ... The majority of washing machines are 27? wide, ...
  • What Should I Know About Washing Machine Capacity? www.wisegeek.org/what-should-i-know-about-washing-machine-capacity.htm What Should I Know About Washing Machine Capacity? ... A load of synthetic fleece sweaters will take up many cubic feet while not weighing as much.
  • What is the cubic foot capacity of my Kenmore washing ... www.shopyourway.com > Manage My Life > Questions 2009-09-21 · What is the cubic foot capacity of my Kenmore washing machine, model number 110.82984110? Report This by Manage My Life. September 21st, 2009.
  • Geeks On Home: What Is the Standard Cubic Feet for a ... www.geeksonhome.com/info_12199449_standard-cubic-feet-washer-dryer... What Is the Standard Cubic Feet for a Washer & Dryer?. ... What Is the Water Capacity for a Washing Machine? How to Measure Cubic Feet. How to Find the Capacity ...
  • Geeks On Home: Washing Machine Capacity Guide www.geeksonhome.com/info_12116692_washing-machine-capacity-guide.html Washing Machine Capacity Guide. Washing machines turned the chore of washing clothes by hand into an ... They typically have between 3 to 3.8 cubic feet of washing ...
  • May 04, 2016 | Washing Machines
    WHAT IS THE SQUARE FOOTAGE OF A 14 BY 70 MOBILE HOME.
    Hi Sharee:
    The square footage is 14 times 70 equals 980 square feet.
    That would be the Floor Area.
    Air conditioners sometimes need to know the building volume so if you have 8 ft ceilings you would multiple 980 by 8 to get 7,840 CUBIC FEET.
    Air exchange is typically are rated at cubic feet per minute and required as "specified Air Changes per Hour.
    An example for your trailer would be 1/2 air change per hour required per building code. 7,840 times 1/2 equals 3920 cubic feet per hour. Divide that by 60 to get 65 cubic feet per minute.
    That would be the minimum air change capacity for your air conditioner if it was also providing required ventilation.
    May 17, 2015 | Heating & Cooling
    What is the fridge capacity in liters?
    Hello Howard;
    My name is Peter. I am a retired field service refrigeration technician.
    Near the top side wall inside your freezer there is a label that gives you the exact cubic feet. Your model number has a rounded off cubic of 23.
    So,
    23 Cu.Ft. x 28.316 = 651.218 Liters.
    Mar 13, 2015 | Freezers
    We have a 50 liter tank that filled up to 4300 psi. in 7 min. how many scfm is my compressor putting out?
    Use this method to determine the fill rate.http://www.ehow.com/how_5001852_calculate-cfm-air-compressor.html#page=1
    The data provided did not provide start and stop pressure. The above method will get you there. Your cubic foot volume on the 50 liter tank is 1.7647 cubic feet to save you some calculations.
    Mar 04, 2015 | Air Tools & Compressors
    I need to know what the voltage for this unit
    Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Air space need sealed subs
    Min volume .66 Cubic feet, Max 1.25 cubic for for the 10" sub,
    Min volume .88 Cubic feet, Max 2 cubic for for the 12" sub
    Nov 21, 2013 | Kicker Solo-Baric L5 Car Subwoofer
    What is the cfm of a goldstar OTR microwave oven model mv-1500mg
    CFM would be "cubic feet per minute", which is a measure of how much air the cooling or vent fan pushes. That specification is not listed in the Goldstar / LG owner's manuals or service manuals I've seen.
    If you might mean the cubic feet (CF) size of the cooking cavity, the M1500-series have 1.5CF capacities.
    Mar 09, 2013 | Goldstar MV-1501 Microwave Oven
    How many cubic feet are in the Kenmore Washer Model 110 80 series
    The cubic feet of the Kenmore washer model 110 heavy duty is 2.8 cubic feet. Measured to the top water line 14.5 inches and using the radius of the tub of 10.375 inches.
    Oct 26, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Nidec a80856-002 - Fan Intel A80856-002 F08g-12b2s1 05ac1 Dc12v Logo
    96 people viewed this question
    Top Nidec Computers & Internet Experts
    David Payne
    David Payne
    Are you a Nidec Computer and Internet Expert? Answer questions, earn points and help others
