Question about Exercise & Fitness
Need new cables
I'm looking for new cables(all 3 of them). The coating starts to break of and damage the pulleys and guiders. I can't seem to find a Dynamix website or the cables I need. SO if anyone knows where to get them please let me know
My mazda protege keeps breaking alternator belts. I've put on serval alternator belts, a new water pump pulley, and 3 alternators and my is still breaking belts
Replace belt tensioner, any other pullys, I worked on ? vehicle where the pully would spin but would stop every so often.
Dec 31, 2015 | 2000 Mazda Protege
Tip
Door sqeaking or falling down? - KitchenAid Kenmore Whirlpool
If the door on your have a stainless steel tank dishwasher is making an annoying squeaking sound or simply drops open unless you support it there is a solution.
The system used to open the door and hold it in place on these models uses rope cables and pulleys. As dust and dirt get on the cables they would make noise usually a creaking or squeaking noise. Sometimes the cables would break causing the door to fall.
The fix for this is a new set of cables and pulleys. They are of a different material that will resist the attraction of dust build up and stay quiet. The link on the end of the ropes have been reinforced to help prevent breaking and the pulleys are of a different bearing design. Over all a very good replacement part.
The part number for this kit is 8194001.(See image below) It comes complete with parts for both sides, be sure to replace both sides even if the noise is only coming from one side. It comes with 2 ropes (24), 2 pulleys (9 &17).
Disconnect the power or unplug the power cord before working on this!
To replace you will need to pull the dishwasher out from the cabinet opening about a foot. Look at the plumbing and electrical to make sure there is enough length to move it out.
Once out you will see the cable (24) that attaches to the spring (18) and to the hinge on the door (not shown), replace the cable and pulley (9).
Do one side at a time, if one side is broken do that side first so you have a a guide to look at if you forget where something goes.
I like to snap a digital picture before I start so I can reference back if I forget what goes where.
on May 02, 2010 | Dishwashers
My blades will not engage. Just stopped while mowing. Model 917.273130. Seat operator present switch seems ok. Belt and pullies look ok. Blades not obstructed. Tractor starts and runs ok.
Check for a broken belt, then the cable and linkages and the pulleys on the deck. Sometimes the two smaller pulleys on the deck break. It should be evident when you put your hand on it and try to turn it.
Aug 17, 2011 | Craftsman Garden
My ride on mower is not cutting the grass as the belt keeps on breaking after doing one strip of the garden iv bought 3 new belts in the space of 4 days it seems to only wear in one side then stretch and...
Have the pulleys checked for worn bearings and improper alignment which can cause this to happen Also the cheaper belts do break when cutting wet grass. Example.... My John Deeres belt cost $75 for a new factory one. A generic Goodyear belt runs $15. Guess what happens when I cut wet grass witha Goodyear belt? Yes it flies off. The Deere belt will stay on for it is made with a protective rubberized coating incased in fabric. If you are using a inexspensive belt you will get a lot of grief from it
Jul 09, 2011 | Husqvarna Garden
Lense wont close
HI there, check the battery first. Make sure the battery are charged. IF yes then the problem create by camera lens guider.The lens guider pin are damaged or dislocated.Thanks.
Feb 28, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Toyota Sienna Power door - SAME THING
Here is a fix on a 1999 Sienna power door cable
Jun 27, 2009 | 2004 Toyota Sienna
Mower drive belt comes off murray 17hp
if you look somwhere next to drive belt then there is a spring. you may have to tighten it. or bend the guiders on the pulleys that the drive belt goes through.
Apr 13, 2009 | Oregon Scientific Oregon Gator Mulcher...
2000 pontiac bonneville rear window cable came off
On my 2000 bville, all four of my windows came off. All four had the same problem. the upper and lower cables go around the pulleys then connect to a plastic piece connected to the track. This plastic piece breaks and lets the cable free. I fixed them all by removing motor assembly and reconnecting the cable with coat hangar wire. Kind of a redneck fix, I know, but beat paying 160 dollars per window for a new assembly that would probably break again!! Good luck!!
Feb 26, 2009 | 2000 Pontiac Bonneville
2000 bonneville, one rear cable on the left rear power window
Removing the steering pump pulley
Don't use a standard bearing puller it doesn't work and may damage the pulley. I went to a local parts store "Salvo" and they had a Ford Power Steering Pump Pulley puller. It works. It seems like you have to put as so much force into it that something would break, but no, it just starts to come off, worth all of the 17.00 I put into it.
Jun 29, 2008 | 1998 Ford Mustang
Exercise & Fitness Logo
42 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
