Question about Exercise & Fitness
Dynamix multigym ymg -4700TC
Where i can i find new cables for my multygym, because my coating is wearing off and start to damaging my pulleys?
Audio video cord for the receiver
what color are the sockets red white and yellow ?. RCA cables
https://www.kogan.com/au/buy/dynamix-20m-rca-audio-video-cable-dynamix/?utm_source=google&utm_medium=product_listing_ads&gclid=Cj0KEQjwyozABRDtgPTM0taCrKsBEiQATk6xDouZTHAocrGkPYYXcbnbv_vjVJupZBzkq7CqqU9tlG4aApoU8P8HAQ
Oct 16, 2016 | Audio Players & Recorders
Tip
Replacing a Spring Pulley on Stairmaster 4000PT Stepper
Stairmaster Stepper 4000PT Spring Pulley Replacement
  1. Remove the bottom cover.
  2. Unhook the pedal arm return spring from the spring hanger.
  3. Remove the snap ring from th pulley shaft. WARNING: To reduce the risk of eye injury, wear eye protection when removing snap rings.
  4. Slide pulley and washer off the shaft.
  5. Before reinstalling the pulley, clean the pulley shaft thoroughly with a clean, dry cloth. Apply a thin coat of multipurpose grease to the pulley shaft.
  6. Slide the pulley and washer onto the shaft. Install the snap ring.
  7. Route the spring under the spring pulley.
  8. Hook the end of the spring over the spring hanger. WARNING: Do not twist the spring during installation. It will wear excessively and reduce the life of the spring.
  9. Reinstall the cover.
How To Replace Spring Pulley on Stairmaster 4000PT
on Mar 10, 2015 | Stairmaster 4000PT Stepper
I have a dynamix muting gym ymg-4700 I have no weight stack pin and I need to know the size so I can buy one. Can anyone help??
Mate just tell them where you're buying the pin that you have a "dynamix muting gym ymg-4700", I'm sure they can find the part number.....
Mar 17, 2016 | Exercise & Fitness
Knocking noise when printing
Check the following:
1. DC motor assembly.
Make sure all the motor plate mounting screws are tight.
2. Idler pulley - DC motor assembly.
Make sure the idler pulley is not binding on the pulley shaft. Check the pulley for wear. Check the idler pulley shaft on the motor mounting plate for damage or contamination.
3. Drive pulley.
Check the drive pulley for wear, binds or damage to the pulley or pulley shaft. Make sure the pulley turns freely on the pulley shaft.
4. Motor drive belt - tray drive belt.
Check the DC motor drive belt for damage. Make sure the belt is tracking correctly on the drive pulley, idler pulley, and motor pulley. Check the tray drive belt for damage. Make sure the belt is tracking correctly on
Dec 11, 2012 | Lexmark X646e Laser Printer
I have just bought a second hand disassembled XL700 Platinum Series multigym and am unsure how the cable runs goes through the pulleys - can anyone help?
You can call these numbers for help from acme fitness. They can guide you through the setup.
Toll Free: 1800 425 7557 Service: 99400 55465 SMS ACME to 56767
Mar 06, 2011 | Exercise & Fitness
Weider pro home gym 355 - the cable that comes up from the bottom pulley, to what does it attach? and how does it attach?
FitnessRepairParts.com has diagrams that may be helpful. For example here is the diagram for the WEBE35560. If you cannot determine where things go from the diagrams you may be able to find a manual.
Aug 16, 2010 | Weider Nutrition Pro 2000 MultiGym
I have purchased a second hand orion delta home gym, without the instuctions. I have put together with the exception of the cables, and i can't workout the pulley cable system. Wwhere can i get an...
hi there i have a instuctions book for a delta orion multigym with a pic of pully and cables if you still looking drop me a line at theheatman@btinternet.com and i'll email you a copy of the layout
matt
Jun 13, 2010 | Powerline P2X Home Gym
Weider 3650 home gym. Delay on the weights dropping back down.
With weider pulleys you will find that either the little retainer L shaped piece has moved on one or more of the pulleys or the pulleys are scraping against each other.<br />The plastic coating on the cables will start to show wear or you will be able to feel it in a while.<br />Also check to make sure the cables are around all the pulleys, and have not shifted to the shafts.<br />
Apr 17, 2010 | Weider Nutrition Weider WEBE8077 Home Gym...
Lost pro power multi gym instructions
How do set up the wires for a pro gym multi gym
May 03, 2009 | Exercise & Fitness
Exercise & Fitness Logo
42 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
