Question about Ricoh KR-5 SUPER II 35mm SLR Camera
The mirror only returns when lens removal, it appears that on his return back it locks when the lens is at infinity. Maybe problem whith the mirror glue???
    Novelist:
  • Ricoh Expert
  • 357 Answers
Sounds like the back of the lens may be sticking too far into the mirror box and interfering with the mirror travel. There are also a couple of bumpers on the bottom of the mirror box, and the plastic has become soft and breaks off, allowing too much travel for the levers. Try another lens first. If it does it with all lenses then you will have to search out a repair facility that still does something so old.
Posted on Mar 25, 2014
Ricoh kr 5 super ii mirror
There are some wide angle lenses that will hit the mirror and not allow it to move correctly. Wide angle lenses go further back on the film plane, so they can't be used with that camera. Try a Pentax.
Feb 08, 2014 | Ricoh KR-5 SUPER II 35mm SLR Camera
While looking through my viewfinder lately, every so often after I take a picture, it stays very dark. Yesterday it stayed that way and wouldn't take any pics. I tried switching lenses but the...
Remove the lens and fire a shot...look at the mirror....does it return? If not, the viewfinder will remain dark. If it's stuck in the up position, you'll need to find the cause but be careful...do not touch the surface of the mirror.
Jul 24, 2011 | Nikon D100 Digital Camera
My Praktica LLC mirror locks up and won't return. The shutter stays open partly or fully.
do you have exact model - this maybe bulb which allows the shutter to stay open for as long as the shutter release is pressed - or mirror lock setting - for macro work to avoid any camera shake when the mirror moves - by locking the mirror
Mar 30, 2010 | Photography
Zmy Minolta Maxxum 35mm camera mirror is locked up
Sounds like the shutter or mirror assemble is damaged and needs repair. This is a major repair that a technician will need to preform.
Nov 20, 2009 | Photography
Cannot see through view finder
mirror locked up? if so, the shutter curtain may not have traveled fully. gently push the curtain to the left until the mirror returns.
or the locking mechanism in the mirror box is not working. if so the camera must be disassembled to remove the mirror box for repair.
in either case the camera should be repaired and adjusted by a camera repair person. there are no new parts for this model Pentax so the repair could be expensive. get an estimate first.
i am assuming the lens cap is off.
Nov 03, 2009 | Pentax K1000 35mm SLR Camera
Can't see through viewfinder (it's all black) and cannot trip shutter or advance film. batteries are new and intact.
Remove the lens and look inside it. Do you see the mirror? If not, your mirror is stuck in the up position. Its flat up against the focusing screen. If the mirror is down, the problem is in the lens, or you still have the lens cap in place.
Check your manual under troubleshooting.
Try setting the shutter speed dial to the M90 position.
Also be sure the batteries are inserted correctly!!!!
If no change yet, you can try to put the mirror back down yourself. With the lens removed, set the camera on its back. You can use your fingers, but I suggest a toothpick cuz they won't leave fingerprints on the mirror and the toothpick should break before you exert enough pressure to really break something. So just try to return the mirror to the 45 degree angle within the mirror box. Be careful not to damage anything in there, like the shutter or the arms that raise and lower the mirror. Depending on where you live, there may be some corrosion or rust on the mirror linkage. It should move easily. If you feel any roughness when you move the miror, that may be the reason it did not return on its own. Then turn it on, off again. At some point, you may want to have this camera cleaned, lubricated and Adjusted(CLA) - after all, its over 25 yrs old.
If all that did not work, you'll need to send it in. Here are some good choices for repair places...
Garry Airapetov in Niles, ILL
Camera Repairs in Avon, IN.
BTW here's a website with several pages about FG...http://www.mir.com.my/rb/photography/hardwares/classics/emfgfg20/fg/index.htm
copy and paste it into your browser.
Oct 10, 2009 | Nikon FG 35mm SLR Camera
When I look through the viewfinder, everything is dark....
First remove the battery. wipe off the battery contacts. reinstall the battery. Battery may be weak, replace.
If that fails, remove the lens. See the mirror in there?
If its stuck in the up position, you can return it by hand. But I recommend a toothpick. It won't leave fingerprints.
Oct 04, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Mamiya 645 Super mirror locked in open position
My mirror somehow got stuck open too, I removed the power winder and grasped the pins in the middle of the silver wheel underneath used to wind the camera. Turn this clockwise until it stops and shutter is completely closed. Test fire camera after. If it doesn't work make sure you wound it all the way.
Nov 25, 2008 | Mamiya 210219 for 645 Pro/Pro TL/Super...
Focus?
The C8 optical tube has a very large focal range. It should be capable of focusing on objects from 15' to infinity. To focus on object at infinity you have to move the primary mirror foward. You do this by rotating the focus knob CCW. Rotate the knob CCW until it comes toa stop them slowly bring the mirror back by rotating the knob CW while viewing the object. It will snap to focus so don't move too fast yor you'll miss it.
Jun 25, 2008 | Celestron NexStar 4 SE Telescope
A spot appears in same location on every picture
take the lens out and blow air inside the camera and on the inside part of the lens.
Jan 10, 2008 | Nikon D40x Digital Camera
Ricoh KR-5 SUPER II 35mm SLR Camera Logo
75 people viewed this question
Top Ricoh Photography Experts
Lyle Siemens
Lyle Siemens
M_Butkus
Are you a Ricoh Photography Expert? Answer questions, earn points and help others
