Question about Nokia 5700 Cellular Phone
Switching on phone not switching on
My nokia6500s-1 on switch not working how can I on it?
There is no other way to switch on you Nokia phone other than using the ON switch.
Get the switch repaired and then you will be able to switch on your Nokia Phone.
Mar 30, 2011 | Nokia 6500 Slide Cellular Phone
I've been trying to call my friend that's out of state for 2 days now. From a landline at my hotel and my cellphone. It says the verizon customer you are calling is not available at this time try your call...
I suspect the message is coming from a Telephone exchange .
A Telephone exchange works by switching your call based on what you dial in as a number it records the whole phone number switches the path of your phone connection to the next path.
(modern exchanges of today record the whole b- number and pass it via c7 signalling on a PCM control channel to the next switches along the route)
(Old step by step exchanges use to switch a call on each number dialed via electro-mechanical rotary switches)
So if the phone of your friend was left off the hook the computerised switch would detect this and time out the phone line to free up the switch from waiting for numbers to be dialed.(This saves computer processor time in the switch)
The switch that your friends phone is connected to would mark your friends phone as unavailable if this was the situation.
When you phoned your friends phone the switch would connect to an RVA (recorded voice announcement -1) and the RVA identifies the switch switch 1-1015-5. if it is a mobile phone and it was switched off a Mobile switching centre would detect this and mark the mobile phone number in a special mobile phone database that is was switched off or out of radio range. When you called the mobile number a RVA would be switched in that says "The number you have called in either switched off or out of radio range " then a pause and then in a fainter sound the switch name would be announced.
Feb 01, 2018 | Cell Phones
Deleting yahoo go from collecting software. Mobile immeatily switched off.3110c. Next time switched on only blinking immeadely getting switch off
try taking out the battery in mobile, then put it back in this might help.
(or)
Solution:-
1. Switch Off Phone (Remove Memory Car And SIM).
2. Star Phone Without Memory Card (But Now You Can Insert SIM)
3. Restore Your Phone (Factory Settings) Change Theme (Less Than 100KB In Size) Leave it Switch On For 10 Min.
4. Switch Off Phone And Leave it For 10 Min. (Remove SIM Card Also).
5. Insert Memory Card + SIM Card And Switch On Phone. 6. Enjoy.. :)
NOTE : -
1. Make Sure To Leave Free Space For Phone Memory Between 500KB +
2. This Will Effected For Next 4 - 5 Months … 3. If Phone Restarts, Then You Know What You Have To Do Now?
Sep 05, 2010 | Nokia 3110 Cellular Phone
My nokia 3110c will not switch on
You will need to take the phone to a Phone repair shop near you and let them know what happened.
Best regards
Jun 06, 2010 | Nokia 3110 Cellular Phone
My nokia 72 phone has suddenly switched off
Dear please reinstall its software. Problem will be quickly solved. Thanks
Jan 26, 2010 | Nokia N72 Cellular Phone
Switch on problem - nokia 3230 Hi, My nokia 3230 mobile got switched off on its own and I am unable to switch it on since few days. Even the logo "Nokia" is not appearing on switching the power switch....
hello ! open the phone check if the on switch contact with the MB is ok if so take it to phone shop make them change the switch .
if there is no change flash the phone i mean reinstall the operating program of the phone.
c u later
Apr 21, 2009 | Nokia 3230 Cellular Phone
Memory Card asking for password
I had to clean my phone so I just switched off the phone, cleaned the phone and then switched on. As switching the phone a message was displayed that memory card has been locked and a password was needed to unlock. Please can you help me with password
Jan 14, 2008 | Motorola Mobility MOTOMING A1200...
Second time
Update your firmware, there is definitely a firmware issue with the phone.
Oct 02, 2007 | Sony Ericsson W800i Cellular Phone
My Phones Second Tiem Having this Problem :| ...
remove the memorycard & sim then try.
if still reload softwere.
Nokia 5700 Cellular Phone Logo
13 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
