Roper RES7648E Dryer
Problem for Roper RES7648E Dryer
Dryer will not start
By wowolfram3 on Jun 07, 2009
When I push the start button my dryer does not turn on. I here it click but nothing. i checked the door switch and i can here the timer working
Solution #1
posted on Jun 09, 2009
Not Rated)
manison88
Rank: Guru
Rating: 89%, 31 votes
if you are sure that your door switch is ok than you have a bad motor
but double check the door switch  the door switch has two wires take them off and connect them together if that makes the dryer work its a bad doorswitch if it doesnt help you have a bad motor
Was this helpful?
Yes
No
Popular Solutions for Roper RES7648E Dryer
Questions and Unsolved Problems for Roper RES7648E Dryer
Do you recommend Roper RES7648E Dryer?
Answer
Answer
Hi, I have an F&P ED56K clothes dryer which I would like to vent outside. I need the rear... (More)
Answer
I just purchased a Siemens Dryer WT46E300 and every dryer selection uses an 85C temp. The only... (More)
Answer
Greetings, I have a two year old Roper REX6634RQ0 electric dryer that has been working like a charm... (More)
Answer
I replaced the motor and it worked fine through a full cycle. Now when I push the start button it... (More)
Answer
it runs for about 30 seconds and shuts off. I disconnected the vwent and cleaned it but nothing also... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
