Question about Polaroid Pmp120-4 4gb Usb 2.0 Mp3 Digital Music/video Player & Voice
To charge the player turn the power switch to the on position
My mp3 player wont charge but will turn on when pouted in
connect the Sansa (via the player's USB cord) to different USB ports on the computer until the Sansa starts to charge. A weak or non-working USB port won't charge the Sansa.
  • Reset the Sansa MP3 player. Slide the player's "Power" switch all the way up to the "On" position. Hold the switch in that position for 20 seconds. The Sansa resets. Try to charge the player.
  • Install the latest firmware onto the Sansa MP3 player. Download the Sansa Firmware Updated (link in References), and then click the link in Resources for the specific model of Sansa you own to learn how to update the player's firmware.
  • May 01, 2012 | Kitchen Appliances - Others
    I have a Sweex Vici MP4 player i think the code for it is MP156 - i cannot turn it on - it only turns on when plugged into my computer but it is fully charged so i dont understand what is going...
    Full charge player's battery. Now you must set the power switch to ON position and next hold on the play-pause button for 2-3 seconds. Repeat this step for soft-OFF.
    Petr
    Dec 24, 2010 | Audio Players & Recorders
    Hi, I have a memorex portable DVD player (MVDP1085) and won't power on. when I insert the power adapter in to the unit the charging indicator starts flahing which means that it's charging the battery and...
    On side of the unit you will find an AV switch. Make sure that switch is on the OUT position. Then power up the unit again and try to play a disc.
    Boards for these units are hard to come by. Most portable DVD players are replaced when they fail due to continued declining prices.
    Aug 18, 2010 | Memorex Televison & Video
    My sandisk sansa wont charge or turn on after plugging in to charge
    Does the computer recognize it at all? These mp3 players have a problem with the power button which you push up to turn on,,,, the switch some times become dislogged and require the consumer to either open it or replace it... you can try to reset the device by holding the power button in on position for 10-20 seconds
    Jan 18, 2010 | SanDisk Sansa Clip MP3 Player
    How do i charge the venturer pvs3361 portable dvd player? do i just plug in the connector from the dvd to the outlet? and let it sit?
    Most of these players have a "charge" switch location on the three position power switch (Charge... Standby... On). If not, just set it to off. The unit normally flashes the green light when it is checking the batter condition, solid green when it is charging and the green led goes off when charged.
    Best of luck!
    Nov 06, 2009 | Venturer PVS3361 Portable DVD Player
    I put my sansa clip to charge and turned it off while in charge and now it does not turn on at all.
    Per their Support Website, try holding the Power Switch in the 'up' position (pushing to the On position) for at least 20 seconds - this will reset the device - do not know if it loses the content or perserves that. If your device is dead otherwise that is a moot point.
    Jun 19, 2009 | SanDisk Sansa Clip MP3 Player
    Wont work
    Hold the Power switch to the off position for 13 seconds it will reset the system (it wont delete memory)
    Feb 09, 2009 | SanDisk Sansa Fuze MP3 Player
    Help
    Your flash memory has become corrupted.. only the manufacturer can repair..I wouldn't try to reformat it...Never force it to run after it has shutdown from low battery. Don't leave it in high heat environment..You could try to connect it to your pc with the power switch in the off position let it charge fully and then before you disconnect turn the power switch on on the player..If thatdoesn't work make sure you are using the pc that connected to the player originally and plug the player with the power switch on and restart your pc. Good luck
    Sep 10, 2008 | Mach Speed TRIO Onyx MP3 Player
    Player is not turning on
    Sometimes I must hold the play button down for over 7 seconds on my unit to get it to turn on. See also the answer to the question on properly charging the unit; i.e, have the slide switch in the "off" position.
    If you are using a USB hub to charge the mp3 player then the hub must be powered.
    Jan 02, 2008 | Coby MP-C582 MP3 Player
    Problem with TOSHIBA gigabeat model MEGX30
    When you attempt to charge the player does they screen display the image of the charging plug? If not the battery may have died, in which case it needs to be replaced.
    Jan 20, 2007 | Toshiba gigabeat X20 (20 GB) MP3 Player
    Polaroid Pmp120-4 4gb Usb 2.0 Mp3 Digital Music/video Player & Voice Logo
    Top Polaroid Audio Players & Recorders Experts
    Owen Barnes
    Are you a Polaroid Audio Player and Recorder Expert? Answer questions, earn points and help others
