Everlast Interval Training Round Timer Logo
A
Anonymous Posted on Feb 08, 2014
How do i change the intervals times - Everlast Interval Training Round Timer
2answers
When should a timing belt be change on a mazda cx
Contact your local Mazda dealer and ask them. Manufacturers all have different intervals for specific type of services and maintenance.
Some vehicles have a belt and others have a chain. In belts, most commonly are changed within 80,000 to 100,000 miles. With chains, as long as you maintain your oil changes up to date, no need to replace. But consider that hard driving affects the overall performance of this component.
Is the transit connect 04 plate cam belt or cam chain can anyone tell me please
My information is it has a belt driven camshaft, it is after all a development of the old escort diesel though the replacement intervals are somewhat extended with 100,000 miles or 120 months, whichever occurs first, being the recommended interval though the Haynes manuals persist in suggesting timing belts are changed at 40,000 miles.
I certainly suggest doing a visual check whenever routine maintenance makes it convenient to do so and then change the belt should it appear dusty, frayed or oily. If there are no recorded belt changes I always change a belt when the information printed on the belt is no longer visible or is so faded it can hardly be read.
The first belt change can perhaps be left to the recommended interval with a minimum but rapidly increasing risk I feel subsequent belt change intervals should be increasingly reduced.
1helpful
I would like to know the interval change of my timing belt on my Jeep Patriot Sport 2.0 2008
I must presume you have verified that you do indeed have a timing belt and not a timing chain. (I'm reasonably certain you have a belt, I think the 2.4L engine uses a chain.) Your owner's manual should specify the replacement interval, typically 60,000 or more commonly 80,000 miles. If you're coming up on the 80,000 mile mark, change it. If you bought it used and it's over 80,000 and you don't know if it's been changed, then change it. If that's an interference motor, it will destroy itself if the belt breaks. When having the timing belt changed (or doing it yourself), it's a good time to change the water pump (even it it's fine....simply because you have access while changing the belt), all hoses and other belts. It just makes sense to do these other things while you are doing (or having done) the considerable disassembly / interference removal required for the timing belt work. Shop around and get the required parts, take everything to a mechanic you trust or take a couple days off work and do it. I don't know you or your level of expertise, so my apologies if I'm preaching to the choir.
Mitsubishi mirage 1995 50,000maitenance requirements
MAINTENANCE INTERVALS FOR 52500 MILES IS ENGINE OIL AND FILTER CHANGE.TIMING BELT CHANGE IS 60000 MILES INTERVAL. MOST OF ENGINE TUNE UP IS DUE AT 60000 MILES INTERVAL.YOU NEED TO REPLACE TIMING BELT, REPLACE ENGINE COOLANT, REPLACE SPARK PLUGS,REPLACE IGNITION CABLES. REPLACE ENGINE OIL AND FILTER. YOU NEED TO SERVICE AND INSPECT ALL THESE ITEMS, AUTOMATIC TRANSMISSION FLUID AND FILTER,BRAKE HOSES, BRAKE PADS,DRIVE SHAFT BOOTS,VALVE CLEARANCE,BALL JOINTS AND STEERING LINKAGE SEALS,DRIVE BELTS,EXHAUST SYSTEM,FUEL HOSES,MANUAL TRANSAXLE OIL,REAR DRUM BRAKE LININGS AND REAR WHEEL CYLINDERS.
Shows a cylinder misfire on 2 detected
If this is the 5.4L engine, check the #2 cylinder COP ( Coil on Plug ) and remove and check the plug for damage.
Not sure when the last time you changed plugs was, the 100K interval is a bit high, plugs should be changed at ~ 50K or 60K miles, as the deterioration at this millage interval, the plug is starting to how enough wear to cause issues. This is my opinion, I am also one to change the O2 sensors at this interval, due to slowed response time on the heated circuit at this age.
No instructions need to know how to operate
The Nikon MC-EU1 Remote Cord is an accessory available for the Nikon COOLPIX 880/885/990/995 4300/4500/5000/5400/5700/8700 cameras. The MC-EU1 Remote Cord is 80 cm long and allows the camera to be fired remotely like a cable release for a film-based camera.
The MC-EU1 Remote Cord's main function is to prevent camera shake. As well as the shutter release function, the MC-EU1 has the following functions.
1. operate the camera's zoom remotely,
2. advance or return images in the playback mode,
3. Controlling interval photography, automatically fire the cameras over a given interval.
Note this is the only Nikon remote cord available NIKON COOLPIX cameras and is only compatible with the cameras listed.
The Nikon MC-EU1 remote cord has two Interval modes, A and B
In Interval Mode A: the first photograph is taken at the start; and subsequent photographs taken at the specified time intervals, thereafter.
In Interval Mode B: the first photograph is not taken until the specified time interval has passed and subsequent photographs taken at the specified time intervals.
These modes can be selected by pressing the MODE button. The device cycles through settings in the order, Remote Mode, Interval Mode A, and Interval Mode B. When the Remote Mode is selected, the LCD panel displays Remote; when Interval Mode A is selected, Interval appears together with the letter A and Interval Mode B is indicated by Interval and the letter B.
The interval Modes, allow you to take photographs one after the other at a selected interval, which can be set in increments of one second to any value from two minutes to twenty-four hours. Interval modes are only available when the camera is in recording mode and cannot be used when the camera is in playback mode.
Setting the Interval
1. Setting the camera to recording mode and the remote cord to Interval Mode A or B, the interval setting will be shown in the remote cord LCD display. Items currently selected for editing will flash. Each time the selection (SEL.) button is pressed, the item selected will change as shown below.
Select the desired time by altering the settings (second [S], minute [M], or hour [H]) one at a time. While the item is flashing, press the down button to decrease the time set, or the up button to increase the time set. The value displayed will change by one each time either button is pressed.
2. After adjusting settings, press the selection button until the display is no longer flashing.
Starting Interval Mode Photography
• Half-pressing the remote shutter-release button has the same effect as half-pressing the shutter-release button on the camera, readying the camera to take a photograph. If the interval is set to less than two minutes when the shutter-release button is half-pressed, the interval display will flash. Choose an interval of two minutes or more.
• Full-pressing the remote shutter-release button has the same effect as full-pressing the shutter-release button on the camera, starting interval mode photography.
• When the camera enters interval mode, it will either take a picture and then begin the count to the next photograph (Interval Mode A), or begin the count to the first photograph (Interval Mode B). The Interval indicator in the LCD display will flash while interval mode is in effect.
Ending Interval Mode Photography
• Half-pressing the remote cord shutter-release button while an interval mode is in progress stops the interval photography.
• Photography will also stop should you run out of available space on the compact flash card; In this case, the number of exposures remaining displayed in the LCD panel will be 000.
The MC-EU1 has a feature that when the zoom button is pressed twice in rapid succesion, the camera will start zooming until this function is cancelled by pushing the button a third time. If this function is not cancelled, no other function is possible with the MC-EU1. If the MC-EU1 does not respond as expected please ensure you have not activated the zoom function.
2002 toyota 4 runner timing belt change interval
100 000km timing belt light on dash should come on when due
1helpful
2answers
Timing Chain Interval
If you have a chain, there is NO replacement interval. ALL 4 cylinder Highlanders have timing chains.
Top Everlast Exercise & Fitness Experts
ADMIN Eric
ADMIN Eric
Kardoc
john h
Are you an Everlast Exercise and Fitnes Expert? Answer questions, earn points and help others
