Question about Refrigerators
Slow flow rate of water from gravity fed water dispenser lg fridge
Water trickles out of water dispenser
  • 1214 Answers
SOURCE: water/ice dispenser not working
Depending on the age of your house, large chunks of minerals may have dislodged in the water piping system, and is flooding the filter cartridge with trash. I had this happen recently on a 15 year old house that water stopped flowing in 4 cold water faucets of the bathroom.
Try this -
1) Roll the fridge out from the wall
2) Turn the water off at the wall.
3) Disconnect the water line from the back of the fridge
4) Get a bucket and stick the line into the bucket.
5) Slowly open the valve and see if water comes out. If it does, let it run for 20-30 secs at a decent flow, then turn off. If not water comes out, then you have a different problem. The cause may be the same, but it's not the refrigerator.
If water does come out, check the bucket to see if there are chunks of mineral buildup in the bottom, or floating in the water.
If there are minerals, then again, let the line run until the water runs clear. Open the valve as full open as you can to increase the water velocities and flush the chunks. Also, if no water comes through the tube, there may be trash in the valve itself, and you will likely need to call a plumber to repair unless your handy. I can describe how to repair, but that is another subject.
If everything flushes clear and you have flow, then get yourself a new filter, and try again. If there was mineral buildup, it is possible that some got through the filter and has built up inside the refrigerator water tubing. That again is another issue that I can help you with.
Posted on Jan 14, 2009
  • 11 Answers
SOURCE: Water flow decrease on refrigerator dispenser
You might have calcium deposits in the supply line.You can unscrew the line from the fridge and turn on the water to see if you have good flow. Have a bucket or pan handy. Let it run for a minute. If it checks out ok then the problem might be in the line attached to the fridge. Those usually come off fairly easy. If so take that off and see if its clogged. You can also check the valve where the feed is connected to the main water.
Posted on Apr 18, 2009
  • 13 Answers
SOURCE: Monogram water flow problem
common low flow is a kinked line or a bad water valve, the solioid valve has a filter that may be dirty. then go from there
Posted on May 03, 2009
  • 583 Answers
SOURCE: I have an LG french door fridge and its water flow is very slow
it indicates the problem of a leaky water tube or a jammed ice chute,check it. most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs. please do not forget to rate the solution.thanks
Posted on Jun 12, 2009
SOURCE: Slow water flow from GE Fridge water dispenser
slow water from my ge refrig side by side. less than a momth old
Posted on Jul 22, 2009
Water flow too slow on lg fridge
The solenoid on the water inlet vale is faulty and need to be replaced. Here is the part to order.
Nov 24, 2012 | LG LFX25960ST Stainless Steel French Door...
Low water flow
Make sure the hose behind the fridge is not kinking up, slowing down the flow rate of water.
Nov 17, 2011 | LG LFX23961 (226 cu ft) Bottom Freezer...
My water dispenser is not working properly. It starts out with a good flow, then immediately slows down to a trickle. It started this after I replaced my filter. I removed the filter and tried the...
Hello, Thank You for using FixYa. I will be helping you today.Have you changed your water filter?If you have one it will be inside the fridge or on bottom in the front. This also happens when the water pressure is to low going to the unit from the house. If all those are ok make sure the tank in the fridge behind the drawers is not frozen,You can use a hair dryer to thaw out the tank
Thank You and please rate my answer if it was helpful...
Jun 22, 2011 | Whirlpool Refrigerators
I have an LG french door fridge and its water flow is very slow from the water dispenser. Can someone please help me fix this problem.
Jun 12, 2009 | LG LRFD25850 French Door Refrigerator
Water dispenser no longer dispenses water. Ice maker still works
Has it stopped completely or just slowed to a trickle. If a trickle you need to replace the filter. If stopped either the feed line to the fridge has been pinched/shut off or the internal line has frozen, or the valve is no longer functional.
May 25, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
May 04, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Apr 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
