Question about Magic Bullet Nutribullet Blender
How to stop my nutribullet from making loud noise when blending
Mine has stopped working. it makes a sound though. i bought it about 2 years ago. is it covered by guarantee and where can it be repaired in WA
You might consider the cost to repair vs purchasing a new one. Depends on the model, but looks like you can get a replacement for $100 or less. Warranty on small appliances are usually a max of one year, but you would have to check your paperwork.
May 25, 2016 | Magic Bullet Nutribullet Blender
How do i repair my nutibullet .I have power but the blades on both extractors are not working . It gives out a loud vibrating buzzing sound when pulsing .last blast i did was watermelon and it worked...
Do not try repair it manually,as its a concern of electronic gadget,& its hazardous.Get it done from a service agent or instead prefer ton buy a new one.I would suggest Magic bullet blender nbr1201.The Magic Bullet consumes less power than Magic Nutri Bullet when you compare Nutribullet Vs Magic Bullet, but it is more when it comes to the price factor. Though it is not that powerful, you can get Magic Bullet at much cheaper price than Magic Nutri Bullet.Go to the link to know.
Nutribullet And Magic Bullet Difference
Feb 23, 2015 | Magic Bullet Nutribullet Blender
Fax number for company called Nutribullet?
If they gave you a number, that is not a fax number, try to call it. Or try to locate their customer service department. Sending a fax about a problem with an order won't ensure that the proper people get the information to rectify the problem.
Also Try calling this number, and filling out the form on the NutriBullet website.
"Our customer service is available Monday through Sunday from 9am to 8pm, Eastern Time by phone at 1-855-346-8874."
https://www.nutribullet.com/customer-service.html
Feb 05, 2015 | Magic Bullet Nutribullet Blender
I bought a nutribullet less than a yr and it just stop working it does not smokeor smells like it burned.
ck where the cup goes onto the top make sure it turns on to lock on that is were the switch is to turn it on
Jan 20, 2015 | Magic Bullet Nutribullet Blender
How do I eliminate excess froth from a fruit blend
try adding a tablespoon of cornstarch it makes a great defoamer i use it all the time
Jan 06, 2015 | Magic Bullet Nutribullet Blender
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Sep 11, 2014 | Magic Bullet Nutribullet Blender
My chef tony hand blender want blend how could i fix this problem it makes noise as if it is blending but it wont blend anything
It happens if the rotor is not getting connected to the engine.
you will have to replace the feed tube, maybe you have blended hot fluids, this could melt the connector in the tube
Apr 06, 2014 | Blenders
Loose Object in Vitamix Turbo Blend 4500
Vitamix has a 5-year warranty. Go to their website and they will send you an empty box with a UPS pick up tag and fix it.
Apr 16, 2017 | Vitamix TurboBlend 4500 Work Top Blender
Machine does not blend at ALL .
I have had great luck talking to Back to Basics - here is their info...if it is new- should be under warranty.
" One of our customer service representatives will respond as soon as possible. To register your product, please click here. If you need immediate assistance, please call us at 866-290-1851. "
Best of luck,
BB
Jun 09, 2008 | Back to Basics 700 Smoothie Pro Work Top...
Magic Bullet Nutribullet Blender Logo
53 people viewed this question
Top Magic Bullet Blenders Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
R.A. Ellis
R.A. Ellis
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
