Question about BenQ FP202W Monitor
Turned off and won't turn back on
Was using then it switched off and won't switch back on...
Ice cusher not crushing
Just maybe, but do you use the same switch? If so, try using another switch, or, your ice crusher machine could be broken, the engine inside it could be water logged.
May 22, 2013 | Kitchen Appliances - Others
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Oct 12, 2012 | Kirby Vacuums
Skill 7292 hand sander won't turn on
a lot of times sawdust gets into the switch contacts and won't allow the tool to operate. I would try turning the switch on/off several times and see if it temporarily helps. Also check the cord. Let me know if you need more assistance.
Feb 23, 2012 | Tools & Hardware - Others
Error code e000580-0000 for canon copier
IF you have an E1 finisher on it, Turn OFF copier the E580 error is most likely related to the stack tray lift motor. Try disconnecting the finisher. That means pulling it away from the copier and unplugging the cable from the back of the copier. Turn the copier back on. This won't solve your problem, but you should be able to use the copier until a tech can have a look at it.
Feb 20, 2012 | Canon imageRUNNER 3300 All-In-One Laser...
My brake lights stay on until I begin to press the brakes my car. When I press the brakes on my car, the brake light won't turn on and won't turn back on. Does this mean I need to replace my brake...
on your brake pedal yuo have a switch to turn off the brake lights when not in use and when depressed turns on yuor brake lights. i would suggest either trying to adjust them on the pedal and if not replace the switch.
Sep 30, 2011 | 2006 Pontiac G6
I have a 1998 Buick Regal GS that the ignition does not go back to off setting . It starts and runs just fine but will not turn off completely. Whta could it be?
Can you get the key out? if so then it is a bad ignition switch. If the key won't remove then the nuetral safety switch from the transmission is not sending a signal to the switch to relase the key and it wont turn off till the selenoid in the column relases the pin that is holding it back. That could be the issue, but I would recommend that you lubricate any moving parts that you see, and shoot some in the ignition switch as well. Use only a graphite lubricant. Worst case scenario, you have to get a new switch.
Aug 17, 2011 | 1999 Buick Regal
Washer won't do spin cycle....and won't start any cycle
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 | Vacuums
When i turn the ignition on and turn the run off switch to on the check engine lamp flashes and it won't start.
Turn the run switch back to the ON position and start the bike. The check light stays on until that switch is on to show it works.
Jul 03, 2011 | 2007 Buell Lightning XB12Scg
BenQ FP202W Monitor Logo
23 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
