Question about HP DesignJet 5500PS InkJet Printer
Error 040000 01dc0079
I had the printer in standby, when I tried to started after 70% the error 040000 01dc0079 appeard! Can you tell me how th fix it?
Panasonic TH 42PA25. Front power switch LED is solid red. SC Board LED (D6583) is not lit. SS Board LED (D6765) is not lit. However, SS Board LED D6769 is lit. I suspect PA or P board.
The TV is on standby mode due to protection; some error in the board. If you have spare boards, try replacing it one by one, starting from display board.
Jul 28, 2012 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Philips DVDR7260h
Hello
Disconnect the recorder from power outlet for one minute and reconnect it again. If the recorder still don't operate well, you have to reset it to factory default settings.* Disconnect the recorder from the power outlet. * Press and Hold down the STANDBY/ON button on the front of the recorder whilereconnecting it into the power outlet. * Release the STANDBY/ON button when STARTING appears on the display. * Wait until the recorder's demo starts scrolling; press STANDBY/ON button again to turn ON the recorder. [All information stored in its memory will be erased. The first installation menu will be appeard on the TV screen. OK.
Feb 02, 2012 | Philips Televison & Video
There are 27 "buttons" on th operation panel of my
Part of the print head appeard to be blockes. The internal cleaning process is sometimes not strong enough to clean this.
Try this, Remove the Cartridges, The box that the cartridges sit in the printer has a green or orange lever on the right hand side, pull this leaver and the print head will come out.
Follow the instructions in the link below, it will tell you how to clean the print head more thoroughly.
http://www.fixya.com/support/r3986425-unblock_print_heads
Replace the Print Head and The cartridges when your finished, print approx 2-5 sheets and it should be fine.
If you find this information useful please rate my response, Thank you for supporting the FixYa Community
Regards GM
Apr 07, 2011 | Canon Office Equipment & Supplies
I have an HP Premium C309g All-in-One Printer. When I turn the printer on, the screen goes blue with "C2FE0065" listed on the bottom. Then the screen goes blank and all the lights start flashing....
The printer has a working mode and a standby mode. It could be going into the standby mode. Pressing the power button once, or sending it a print job will usually take it out of standby mode.
Most HP All in Ones will give a problem message on the screen. Your printer may have a more involved problem and you should go to the (hp.com) printers support page at HP. When you get the support page for that printer, type the error code in the search box.
If you are plugging it into the RJ45 Network connector (without a network) you may need to use the printer setup settings to tell it what type of connection to use ( USB or Network).
If the printer is connected to your telephone line and you are using a DSL internet connection you need to put a DSL filter on the telephone line going to the printer. The printer may be picking up DSL internet signals. Again the printer setup utility will ask you what type of connection you are using.
Mar 06, 2011 | Office Equipment & Supplies
Printer error see your documentation
My printer appeard "PRINTER ERROR SEE YOUR DOCUMENTATION" on the printer's panel, I turn the printer off an then put it ON but still the message is coming again. So I cannot printer or do anything. How can we solve fix this problem?
MY printer model is: EPSON STYLUS OFFICE TX300F
Jul 24, 2010 | Epson LX-300 Matrix Printer
Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Jun 06, 2010 | Canon iRC3100 Printer
I do not see anything in the manual for error code 70 on the mfc 290c model Brother. I keep getting a message to check teh User's Manual for maintenance and trouble shooting. TEh machine is less than 6...
code 70 Error are caused by misconfigured system files,If you got code 70 error then 96% chance that your computer has registry problems.I will tell you how to fix it under 2 min and for this you can visit code http://tinyurl.com/nznbpm
Jun 20, 2009 | Brother MFC 210C All-In-One InkJet Printer
Download standby error
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E197 0000 Erroneous communication with printer engine E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
Apr 10, 2009 | Office Equipment & Supplies
Error message 70
Can you verify the error message to be 70? Error Codes for the 4100 starts at 71 as shown in the link below.
http://tinyurl.com/yvcv35
It could be error 7D. You may try to remove the toner cartridge from the printer and slide the corona wire cleaner and put it back on. Do this with your fingers crossed. :-)
Error messages like these are not user serviceable. Another bet is to unplug the unit, wait a couple of minutes and plug it back again. If the error persists, professional service is required.
Best Regards
Jan 08, 2008 | Brother IntelliFAX 4100 Laser Fax
HP DesignJet 5500PS InkJet Printer Logo
Seeker5211
Seeker5211
