Question about Pioneer VSX-D510 Receiver
Pioneer av kept switching to standby from on and now won't startup at all. Have disconnected all speakers and still won't start ?
Was working fine with a set of Sony speakers , then the sound went followed by the av switching from on to standby followed by no visible signs of power. I have popped the lid and replaced 3 glass fuses , but still nothing happens when I press the power button.
SOURCE: standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Posted on Oct 14, 2008
SOURCE: problem with pioneer vsx-916 av receiver
i have been using this with two speakers and was working perfectly fine . recently i bought two floor standing speakers and worked fine when connected . When i tried connecting all four speakers it showed overload kindly tell me how this could be solved
Posted on May 02, 2009
dunnbiker
  • 8546 Answers
SOURCE: won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
Posted on May 16, 2009
  • 19 Answers
SOURCE: I own an Pioneer CD
On the first board (where the power enters) there is a tall 3 pronged switch, if you turn the board over and solder a piece of wire to the 2 outside prongs, you will find that the Amp works normally apart from that the display reads Cd closed when in Cd mode.
Posted on Jun 22, 2009
  • 128 Answers
SOURCE: My Pioneer VSX-D1S A/V receiver will not power on
Unit is pretty old I had one of these back in 98-99.
Time to upgrade a service tech is going to cost you $150 just to open it up and figure out whats bad.
Pioneer ok but check out Denon's line of receivers Onkyo is good too but they have a high rate of repairs
Pioneer doesn't make them like they used to that D1S was a tank, had tons of audio / video inputs was one of the first with video upconverting had lots of power and a great front display panel. BUT technology has come along way and pioneer hasn't kept up. They even stopped making high end TV's a few years ago even though they were regarded as the best sets out there.
check this out
Denon AVR-4310CIgoogle it they sell for ALOT less than sticker I bought one for $1299 with a 5 year warranty
Hope that helps
Posted on Feb 19, 2010
Testimonial: "@thebigdoghim, thanks for the very constructive feedback. I was 80% certain that the cost to diagnose the problem alone would be in the triple digits."
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
When iam turning on its suddenly go to standby in seconds i have checked with service center their is no problem in it how to check the speakers circut or any wire short circut how to solove this
Please disconnect the speakers and try to swicth ON,If it switches ON without going to standby then one of your speakers is faulty.
After disconnecting the speakers and the set stil goes to standby it means one onre of the protection circuits in your system has been activated,check your fan if its rotating,the output ics if are not burnt or shorted.Also check your power supply section.thanks.
May 12, 2016 | Marantz SR 6007 AV Network Receiver
Why does it keep going back to standby?
First, check your owners manual. There may be some info in there on things that can cause it to default into standby.
Second, if you've just bought it, make use of the warranty.
As we have no info on the make and model we are talking about, cannot be more specific, but some home systems, depending on design, are not very tolerant to running with no load (speakers), or unbalanced loads. ie; no speakers attached, or speakers of differing unmatched impedance's, especially so at higher outputs. So not a good idea.
But this sounds more power supply related. Unplug the unit from the wall for a few minutes or so. When you start it up, do so with the volume all the way down. If this does not allow you to power up, you could inspect (measure) the internal fuse(s), however, this could void your warranty. See step 2. Good luck.
Feb 25, 2016 | Audio Players & Recorders
Error b22110
For the iControl AV2 app to work 'Network Standby' should be switched on. Check page 72 of the receiver's manual.
You can download the manual here:
https://www.pioneerelectronics.com/PUSA/Unassigned-Content/Manuals/VSX-52+OPERATING+INSTRUCTIONS
Aug 30, 2014 | Pioneer VSX-52 AV Receiver
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
I've got a vsx-920-k Pioneer receiver with s-11 Pioneer speakers and a s-21w Pioneer subwoofer. All of a sudden my sub stopped working and it seems like it's stuck in standby mode (blue light...
The manual is here...
http://www.pioneerprodj.eu/eur/products/42/99/S-21W/media.html
Flashing Blue is not defined in the manual.
Have you tried changing the Auto Standby switch to ON?
You can prove if the sub amp will respond to a known good input by TURNING ITS VOLUME DOWN tp start and just feeding it ANY RCA output from the receiver while playing, say, FM (to keep it simple). That way you would known in which direction the problem actually lies (internal or external).
Jul 05, 2011 | Pioneer VSX-C300 Receiver
I'm connecting Bose 901 speakers with an Active Equilizer hookup required to my new Pioneer VSX-520. What in/out puts should be used ??
The solution to using 901's in a multichannel rig works best when you have individual Front Right and Left Pre-Outs but this receiver doesn't have them so a compromise is in order.
First some background.
The use of 901's Active EQ (or any external processor) in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor which could introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
In an AVR, if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Your Pre-Outs get us around that possibility and limitation but it also means you need a moderately powerful amp for your 901's.
http://www.retrevo.com/support/Pioneer-VSX-520-K-Receivers-manual/id/23653ag911/t/2/
This works for all models of AV receivers when you want 901's as Front L&R speakers...
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them, in your case maybe the CDR or DVR/VCR outputs.
On many AVR's, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others (yours), you have to borrow the signals from a typical CDR or DVR/VCR Output RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won
Feb 13, 2011 | Pioneer Audio Players & Recorders
Twice now my Pioneer VSX-819H has shut down. Can not get any power to it. The first time I'm sure the phono pre-amp caused a surge. I no longer have it hooked up. The servicer said nothing was wrong and...
I found this for the VSX918, 818. Perhaps it's similar.
The power does not turn on. • Disconnect the power plug from the outlet, and insert again.
• Make sure there are no loose strands of speaker wire touching the rear panel. This could cause the receiver to shut off automatically.
The receiver suddenly switches off and the power indicator
blinks.
• After about a minute (you won’t be able to switch the unit on during this time), switch the receiver back on. If the message persists, call a Pioneer authorized independent service company.
Resetting the main unit
Use this procedure to reset all the receiver’s settings to the factory default. Use the front panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the ADVANCED SURROUND button, press and hold the
STANDBY/ON button for about three
seconds.
3 When you see RESET? appear in the display, press ‘
ST –’. OK?
shows in the display.
4 Press SOUND RETRIEVER to confirm.
OK
appears in the display to indicate that the receiver has been reset to the factory settings.
Mar 02, 2010 | Pioneer VSX-819H-K A/V Receiver
No sounds
Test one speakers at other amp to ensure its working. Amp is going into probable protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If sound connect speakers and av cables one by one and test each one on its own until amp switches off, or no volume. Investigate from there were prolem is.
Feb 25, 2009 | Pioneer VSX-D710S Receiver
Problem with pioneer vsx-916 av receiver
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
Jan 21, 2008 | Pioneer VSX-915 Receiver
Pioneer VSX-D510 Receiver Logo
26 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
