Question about Activision Tony Hawk: Shred
Connect Board tony hawk shred wii - Activision Tony Hawk: Shred
  • 6 Answers
SOURCE: tony hawk shred board will
I had the same problem. Do not use the batteries that come with the board. Use slightly older batteries and re-calibrate the board, this should work.
Posted on Dec 25, 2010
  • 4 Answers
My husband was ready to throw this game out the window instead of returning it because he was so upset...so nice for our 10 year-old on Christmas morning. Researched online and lots of people said putting two older batteries into the board with two of the new ones. We did that and also had to move the couch into the hall and then it finally calibrated!! Don't give up keep trying everything but the two older batteries helped. Once it was calibrated we moved the couch back and it seems to work fine. So far it seems like a cool game!
Posted on Dec 26, 2010
SOURCE: cant calibrate Tony Hawk Shred
Don't waste your time!! Throw the piece of **** in the trash!! I have been trying to get it do work must of the day also. Tired all the tricks posted around the net. My wife bought this junk off Ebay, so we are basically out $80.00. For those who can return yours, run don't walk and get your money back.
SOURCE: I can't get my Tony
you need to sinc the xbox 360 to the shred board by pushing the connect button on the xbox directly under the circle power button and above the B slot. You really can see it but you have to get up close, after you hit connect to the xbox hit it lights up, you conect to your board with the small button. We were having the same issues and after we hit both connect buttons on the xbox and board we were good to go
  • 14 Answers
SOURCE: my xbox 360 tony hawk
we spent a day trying to calibrate the shred board, after much searching on the internet we found the solution that worked for us straight away was too - put two old and two new batteries in the board, we also elevated the board on a small stool this did the trick and now we can actually use it. Huray!!!
Lost sensor for tony hawk shred wii game
The best place to look is on Ebay.
Oct 22, 2011 | Nintendo Wii Console
The Tony Hawk Shred board will not connect with the Wii...screen says "The skateboard controller is disconnected. Make sure the skateboard controller is turned on." When we press the power...
First turn on the little box you plug into the usb of the wii,then turn on board after make sure the wii sencer bar is also able to pick up board as well the red light will flash just let it go and should work make sure the blue lights are on on the board.
Sep 03, 2011 | Activision Tony Hawk Ride for Nintendo Wii
Cant calibrate tony hawk shred board to my wii. I've tried everything
At last! My Son's Tony Hawk Shred board was one more try from being thown down the garden, as i have been trying since Christmas day, & finally there it was a board i could use. I've followed all bits of advice in a number of differant ways --- here's what worked for me, Turn off at the wall Sky TV, Turn off all lights (only tv turned on), put my crutches in another room (because large metal objects interfere with soft ware), Remove dog from room, Put senser bar on floor, Turn Wii console side on so that Dongle faced away from tv (aiming into centre of room), Place Shred board on floor facing tv/senser at about three feet away. Start process of game set up untill you get to choose a profile, Select profile, press & hold for 5 secs start button on board untill the four blue lights start to flash at a rate of about one flash per sec, then hold on same button untill blue lights flash quickly, then press & hold Dongle button untill Dongle light stays on, with in 2 secs game calibartion instructions start, BEWARE Tony Hawks responce when process starts is as annoying as not being able to get board started. Good luck when up & running it is one Awesome game!
Jan 01, 2011 | Activision Tony Hawk Ride for Nintendo Wii
How to set up tony hawk shred board. on the tv it says to connect the board, and the light on the board keeps blinking green
You need to connect the board to the XBOX before you can calibrate...press the Connect button on the main console (on my XBOX 360S it is directly to the left of port 1 for the game controller), then press and hold the tiny button far left on the board controller. That's as far as I got, it won't calibrate to save my life!
Dec 26, 2010 | Activision Tony Hawk: Shred
I can not get my tony hawk shred board to calibrate
If you are trying to run on a softmod wii - then use Greko OS to get it running
Dec 25, 2010 | Activision Tony Hawk Ride for Nintendo Wii
Tony Hawk Shred board will not calibrate. Help!
I had the same problem. I turned the WII so the dongle/sensor that comes with the game is facing the skateboard with a clear line of sight between the dongle/sensor and skateboard. Now it's able to calibrate. Hope this works for you.
Cannot calibrate Tony Hawk Shred for Wii
I had the same problem. I solved it and got the board to calibrate immediately when I replaced the brand new batteries with used batteries. Brand new batteries apparently make the lasers very sensitive. You have less sensitive sensors with the used batteries. I just took some AA's out of my cable remotes. The game is awesome once you get it calibrated. I felt your pain for an hour or so.
Tony Hawk shred board will not calibrate to the wii.
i had this same issue try turning off the lights leaving only the light from the tv....worked like a cham for me!
Dec 17, 2010 | Activision Tony Hawk Ride for Nintendo Wii
Activision Tony Hawk: Shred Logo
Top Activision Video Game Consoles & Games Experts
Person On the...
Level 1 Expert
Zhenya Ogorodnikov
dj ese
Level 1 Expert
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
