Question about Samsung BN94-02699F Main Board for LE32C450E1WXXU BN41-01331B
I have problem samsung le26c450 main bn41-01331b blin king st/by dont change ch and some times close
Do lg tvs work
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Nov 19, 2016 | LG Televison & Video
Samsung UN55B7000WF RED LIGHT FLASHES CLCIKING SOUND BACKLIGHT FLASHES
Hi Ab7775,
1. Pl check st by 5 or 3.5 volts.
2. If it is ok, check power on 5 or 3.5 volts. Is power on voltage stable ? If this is pulsating with cliking sound, it is the main board. Otherwise it should be the power supply.
3. Please also check all the other voltage for short with ground.
You can also check the power supply board separately. Remove the connector going to main board. Put a 1k res between st by and power on pin. Plug in the ac, if all the voltage appear, your power supply is ok.
I am on line if possible please do this checking and let me know the result.
Good luck.
Aug 09, 2016 | Samsung Televison & Video
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
HAI I'm priya from chennai i bought a ac in a
If you are looking for another manufacturer besides samsung, try mitsubishi.
Jun 13, 2009 | Heating & Cooling
Source code for stack using arrays in c++
stack in c using arrays
/* Program of stack using array*/
#include
Dec 05, 2008 | Computers & Internet
Sony blinks 6 times wont turn on...is it worth fixing
replace on the D board
IC6501
IC8002
C6510
C8027
C6532
C8037
Hope this fixes you, if not then alot of other might get theirs fixed. please leave your feedback!
this fix cam from sony tech just 5 minutes ago.
FIxes problems with tv not turning on when cold, very hard to turn on. or people that have to unplug and plug in again to get it to come on. I usually dont give info like this for free as I'm a head tech.
good luck
Jun 26, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Samsung BN94-02699F Main Board for LE32C450E1WXXU BN41-01331B Logo
261 people viewed this question
Henry  Thomas
Henry Thomas
