Question about LG DU-27FB32C TV
How to take off key lock if you only have the cable remote
How do I unlock my TV it has key lock and I don't have a remote
Fixing key-lock on TV without a remote - television westinghouse ...
ask.metafilter.com/166214/Fixing-keylock-on-TV-without-a-remote
Sep 27, 2010 - I cannot change my Westinghouse LCD TV's channel, and it's driving me bonkers. ... The cable remote probably has a mode which causes the cable ... Plan B. is if you have an HDMI out on the cable box you could ... Note don't pay more then $8 for HDMI cables you can order them on Amazon for about $3
Are You locked Out? ' Techlore
www.techlore.com/article/are-you-locked-out
If you have a blank screen with a red key on the bottom left, simply press the (function or .... If you have the original remote (RC-A07) for Sinotec tv, then press and hold down.... I need to know how to unlock it, my fiance has managed to push a bunch of .... V-Chip is locked on a Trutech T2000-FT and we don't know the code.
Jan 29, 2016 | Televison & Video
How to reprogram porsche boxster key remote
Boxster key remotes are reprogrammed by put the key in the ignition turning the ignition on but not starting the car, then hold down the door lock on the remote for like 5 sec. Ta da... She's reprogrammed.
May 11, 2014 | 1999 Porsche 911 Carrera
Can't program comcast remote to yamaha yas-101
The only thing i was able to do was to use this link and make the remote learn the functions by following the instructions on the Yamaha web site for the sound bar to AUX. YAS 101
http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/yas-101/7598/6609/
I then used the instructions below to volume lock the aux so that i did not have to switch back and forth from cable to aux to adjust volume and change channels
Setting Global Volume Lock
Global Volume Lock will force the volume and mute keys to be controlled by one device.
  1. Press and hold the "Setup" key until a device key blinks twice.
  2. Type in the code 993. A device key should blink twice.
  3. Press and release the device key for the device you want the volume locked to.
  4. You will get two blinks if the lock is successful.
Jul 03, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
Battery unplugged, hood closed and all doors locked. We can not unlock any doors to get into the car with the keys. Door it have something to do with the chip in the key or the automatic door lock...
You need a car battery and a set of jumper cables. Connect one positive side to the battery cable on the starter and ground on the body of the vehicle. And the other ends on the battery. Then use the remote.
Aug 17, 2011 | 2004 Pontiac Grand Prix
Bought a used tv with remote and the channels are locked, how do I unlock so I can get all the channels?it is a Zenith TV.
on the remote,press cable once,then press& hold setup until the cable key blinks twice, then release setup,enter 9-7-3,press CH once, the cable key will blink four times......done .......hope that helps
Feb 18, 2010 | Televison & Video
Remote alarm was off for 10mins now car wont do anything
well the alarm would not lock the key in the ignition.. But the only thing that would lock key is dead battery or bad battery cables. dirt on the cables and battery terminals.. I would check that before anything else. That problem is common (mostly on batteries with side posts.
Aug 23, 2009 | 2002 Oldsmobile Alero
My key wont unlock the trunk anymore but the remote opener does.
There is a cable that runs from the key cylinder to the latch mechanism. There are clips that hold the cable housing in place, and if one of those comes loose then turning the key just moves the housing without releasing the latch. Check the clip closest to the latch. To get the trunk open drop the back seat, crawl in, and pull on the cable.
It is also possible that the cable is broken or damaged and needs to be replaced -- I assume you will then need to replace the enrite assembly.
Apr 08, 2009 | 2000 Chevrolet Cavalier
Remote doesn't work
I have lose my remote and I have parental code lock n Iam using my cable remote, but can not key my code n cable remote to deleted parental off.Please help me
Feb 07, 2009 | Orion STV2763 27" TV
Want to use cable remote 4 tv as well
reade the booklet that came with the cable box to get the program #'s for the remote to control you tv as well
Dec 25, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
27 people viewed this question
Computer Repairing
Computer Repairing
