Question about Sharp LC-26D6U 26 in. LCD Television
Cannot get speaking sound from DVD to play on tv
Component cable used. Background music of DVD plays but not speaking. DVD works fine on laptop. Video output is fine.
  • 979 Answers
SOURCE: hooking up portable dvd player to sharp aquos tv
Audio and video out from the DVD unit go to the A/V In of the Sharp....Accordianman
Posted on Nov 26, 2007
  • 53 Answers
SOURCE: Sharp 46D62U incompatability
Most likely a defective Main Board. I suggest calling Sharp 1-800-237-4277 to locate your local Sharp Authorized Service Center.
Posted on Mar 14, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Posted on Dec 31, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
  • 11800 Answers
SOURCE: Dear Sirs, I have a
The control processor has failed and since its soldered on the logic board that must be replaced in its entirety. Unfortunately,  since this tv is sold only in Asia, it will be very difficult finding parts for it outside of the official dealer. Best is to take your tv to one, they will be able to order the part directly to Sharp.
Posted on Sep 10, 2010
Pioneer VSX-D509S 5.1- No voice audio on DVDs
try the dvd player settings to bitstream out in setting menu ok not pcm best to use coxal cable to get fiull 5.1 suround
Jan 20, 2008 | Pioneer VSX-D509S Receiver
No speach volume when playing ps3 dvd through hdmi
it is not using the correct sound file. try another dvd.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
Sound
When u can't hear any "speaking" try the changing the audio setting of the player.
If no change I'll need to see the remote, a pic will do
Rifaa
Nov 17, 2008 | Televison & Video
Cannot play VHS
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
Feb 28, 2008 | Samsung DVD-V6700 DVD Player/VCR
Sony DVP-NS315 cant play only Video Disc
If you are using just a "yellow" ended cable for the video, maybe your custom settings are set to use "component"? I have been using this same dvd player for a while with the component video out and it works fine. I hope this helps.
Sep 30, 2007 | Sony DVP-NS315 DVD Player
DVD's music and background but no talking
Try adjusting the sound on the tv. If you go into the "user" audio options you can select between normal and True Surround SXT. That may work. Otherwise, try playing with your dvd player's options. The problem I'm having is the tv plays the sound before the picture.
Sep 19, 2007 | LG 42PC5D Television
Component Video Problem
The problem is not with your tv it's with your dvd player. You have to go into the setup on the dvd player and change your output setting to component.
Jan 18, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Mom was hitting buttons and now DVD plays Blue and White!
I think your mom changed the DVD output setting. Using the remote, go to the Setup Menu, then select DVD Setup. Scroll down to the Alt Video Out option. It will either be set to "Component", S-Video, or "Off". It needs to be set to the type output you are using to go from your Go Video deck to your TV. If you are using an S-Video cable, then set it to "S-Video", if using Component cables (Red, Blue, and Green cables), then set to "Component". Otherwise it should be set to "Off".
Hope this helps.
Nov 26, 2006 | GoVideo DVR4000 DVD Player/VCR
Sharp LC-26D6U 26 in. LCD Television Logo
11 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
