Question about Sharp AR-M208N Copier
Download driver free m208n - Sharp AR-M208N Copier
Need the driver for Sharp AR-M208N
try to go the site and you download www.sharp.com/support
Jun 08, 2011 | Sharp AR-M208N Copier
How do I get our sharp AR-M208N to work with windows 7?
go to www.sharp.ca
Select Service Support > Downloads and slect Photocopiers. This machine is listed as an AR 208. Click on DONE and the drivers will be presented. Scroll to the PCL English version and download from there.
Jul 13, 2010 | Sharp AR-M208N Copier
Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Jan 20, 2010 | Sharp AR-M208N Copier
How do you replace the drum on a sharp ar m208n
just remove the old one and insert new
Nov 11, 2009 | Sharp AR-M208N Copier
Sharp AR-M208N with OFH4-00 error code
Hello sir; This code require simulation to reset the procedure as follow; press "#", "interupt", "clear", "interupt", then enter 14 press start. turn power off and back on, then all set.
Sep 27, 2009 | Sharp AR-M208N Copier
Sharp AR-M208N copier with 124,387 copies made
I buy and sell used copiers in southern California. That machine is pretty well aged and getting to the point where parts are not available. I would consider myself lucky to receive $400 for it.
Oct 21, 2008 | Sharp AR-M208N Copier
Shart AR-M208N Toner Replenishing
Have you removed the seal from the toner before installing it in the machine? If so, make sure it's all removed. If that looks ok there may be a problem with your machine.
The 208 is a fairly new machine, you might still have warranty on it. I'd check with Sharp or with the company you bought it from for repair info.
Oct 15, 2008 | Sharp AR-M208N Copier
Sharp AR M208N
On that page under Vista is a Post Script driver. You download by putting in PPD as your driver type.
It would be nice to have the PCL driver but the postscript should get you by unitl they release the rest of the software.
Jul 31, 2008 | Office Equipment & Supplies
Sharp AR ? M208N
You have to use a Vista driver for that machine, check sharp's website and see if they have a driver specificcaly for Vista.
Jul 31, 2008 | Sharp AR-M208N Copier
Sharp AR-M208N Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
