Question about Toshiba Qosmio G30-188 Laptop DC Car Adapter (15V/6A 120Watts) by Amstron (Generic)
Qosmio G30 flashing DC In led with error code 72
Using battery or ac power I get this error code on dc in led and pc does not boot up
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 157 Answers
Replace the adaptor and then check.
Posted on Feb 11, 2014
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
Using Battery or AC power my Toshiba G30 gives a flashing amber DC IN LED and will not boot up
You have a trouble in the video chip of this main bord must to be reboulding to solution it ! post please
Feb 08, 2014 | Computers & Internet
QOSMIO G30 no start up only flashing DC-IN LED
Rebouldin resoldering the video proccesor this is the problem or change the main bord a new !
Feb 06, 2014 | Toshiba Computers & Internet
Qosmio G30 No start up Flashing DC-In LED
Yuo have a trouble in the main video bord change it or make a rebouling soldering to the video proccesor this is the solution
Toshiba Qosmio G30 Flashing DC- In LED on power up and cannot start laptop
I found some G30 with defective memory and it cause boot up problem. You can try to remove one memory to test it. Testing the laptop with a good working memory is the best way.
Feb 06, 2014 | Toshiba Qosmio G30-166 Laptop AC Power...
My Laptop won't power up
try plugging it to another same brand laptop. if the result is the same that means ur power adapter is faulty, if it's ok with other laptop then its ur laptop's power connector & motherboard is faulty
Aug 09, 2012 | Dell Inspiron 1545 Black Intel Celeron 900...
I have a compaq nc6000 which wont boot up it trys to fire up then it goes off i have got to run but then it went back to this not booting up
Check and see if your DC connector is loose:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 02, 2011 | Compaq Presario Notebook
Hi all, TECRA M10 Model No. PTMB3A000N004 Laptop was on standby and was left open all night. Next morning, no response and would not 'wake'. Laptop was plugged in on charge. Hard rebooted...
take a look:
Power Status Check
The following LEDs indicate the power supply status:
q Battery LED
q DC IN LED
The power supply controller displays the power supply status through the Battery and the DC IN LEDs as listed in the tables below.
Table 2-1 Battery LED
Battery LED Power supply status
Lights orange Quick charge.
Lights green Battery is fully charged and AC adapter is connected
Blinks orange (even intervals) The battery level becomes low while operating the computer on battery power.*1
Flashes orange The power switch is pressed on when the battery level is low.*2
Doesn't light Any condition other than those above.*1 Low Battery Hibernation will be executed soon.
*2 Low Battery Hibernation has already been executed.
Table 2-2 DC IN LED
DC IN LED Power supply status
Lights green DC power is being supplied from the AC adapter.
Blinks orange Power supply malfunction*3
*3
When the power supply controller detects a malfunction, the DC IN LED blinks and an error code is displayed.
Error Code Check
If the power supply microprocessor detects a malfunction, the DC IN LED blinks orange. The blink pattern indicates an error as shown below.
q
Start
Off for 2 seconds
q
Error code (8 bit)
"1"
On for one second
"0"
On for a half second
Interval between data bits
Off for a half second
The error code begins with the least significant digit.
Example: Error code 12h (Error codes are given in hexadecimal format.)
Convert the DC IN LED blink pattern into the hexadecimal error code and compare it to the tables below.
q DC IN
Error code
Meaning
10h
AC Adaptor output voltage is more than 16.5 V.
12h
Current from the DC power supply is more than the limit (6.05 A).
13h
Current from the DC power supply is more than the limit (0.5 A) when there is no load.
14h
Current sensing IC is not normal.
q Main Battery
Error code
Meaning
21h
Main battery charge current is more than 6.05 A.
22h
Main battery discharge current is more than 0.5 A when there is no load.
23h
Main battery charge current is more than 3.1A when DC IN direct charge is off.
24h
25h
Main battery charge current is more than 0.3A when the battery isn't being charged.
q S3V output
Error code
Meaning
40h
S3V voltage is not more than 3.14V when the computer is powered on or off.
45h
S3V voltage is not more than 3.14V when the computer is supports CV and is booting up.
q C5V output
Error code
Meaning
50h
C5V voltage is more than 6.00 V when the computer is powered on or off.
51h
C5V voltage is not more than 4.50 V when the computer is powered on.
52h
C5V voltage is not more than 4.50 V when the computer is booting up.
53h
C5V voltage is not normal when the computer is suspended.
54h
C5V voltage is not normal when the computer supports CV and is suspended.
55h
C5V voltage is not more than 4.50V when the computer supports CV and is booting up.
q C3V output
Error code
Meaning
60h
C3V voltage is more than 3.96 V.
61h
C3V voltage is not more than 2.81 V when the computer is powered on.
62h
C3V voltage is not more than 2.81 V when the computer is booting up.
63h
C3V voltage is not normal when the computer is suspended.
64h
C3V voltage is not normal when the computer supports CV and is shut down.
65h
C3V voltage is not more than 2.81V when the computer supports CV and is booting up.
q PPV output (PCU core voltage)
Error code
Meaning
70h
PPV voltage is more than 1.56V when the computer is powered on or off.
71h
PPV voltage is not more than 0.68V when the computer is powered on.
72h
PPV voltage is not more than 0.68V when the computer is booting up.
73h
PPV voltage is not less than 0.68V when the computer is powered off.
q BGVSNS output
Error code
Meaning
80h
BGVSNS voltage is not more than 1.62V when the computer is on or off.
81h
BGVSNS voltage is not more than 1.02V when the computer is powered on.
82h
BGVSNS voltage is not more than 1.02V when the computer is booting up.
83h
BGVSNS voltage is not less than 1.02V when the computer is powered off.
84h
BGVSNS voltage is not more than 1.62V when the computer is suspended.
q 1R5-E1V output
Error code
Meaning
90h
1R5-E1V voltage is more than 1.80V when the computer is powered on or off.
91h
1R5-E1V voltage is not more than 1.275V when the computer is powered on.
92h
1R5-E1V voltage is not more than 1.275V when the computer is booting up.
93h
1R5-E1V voltage is not less than 1.275V when the computer is powered off.
94h
1R5-E1V voltage is not more than 1.275V when the computer is suspended.
q 1R8-E1V output
Error code
Meaning
A0h
1R8-E1V voltage is more than 2.16V when the computer is powered on or off.
A1h
1R8-E1V voltage is not more than 1.53V when the computer is powered on.
A2h
1R8-E1V voltage is not more than 1.53V when the computer is booting up.
A3h
1R8-E1V voltage is not less than 1.53V when the computer is powered off.
A4h
1R8-E1V voltage is not more than 1.53V when the computer is suspended.
q 2R5-SNS output
Error code
Meaning
B0h
2R5-SNS voltage is more than 3.00V when the computer is powered on or off.
B1h
2R5-SNS voltage is not more than 2.125V when the computer is powered on.
B2h
2R5-SNS voltage is not more than 2.125V when the computer is booting up.
B3h
2R5-SNS voltage is not less than 2.125V when the computer is powered off.
B4h
2R5-SNS voltage is not more than 2.125V when the computer is suspended.
q 1R25-E1V output
Error code
Meaning
C0h
1R25-E1V voltage is more than 1.50V when the computer is powered on or off.
C1h
1R25-E1V voltage is not more than 1.063V when the computer is powered on.
C2h
1R25-E1V voltage is not more than 1.063V when the computer is booting up.
C3h
1R25-E1V voltage is not less than 1.063V when the computer is powered off.
C4h
1R25-E1V voltage is not more than 1.063V when the computer is suspended.
q 2R5-E1V output
Error code
Meaning
D0h
2R5-E1V voltage is more than 3.00V when the computer is powered on or off.
D1h
2R5-E1V voltage is not more than 2.125V when the computer is powered on.
D2h
2R5-E1V voltage is not more than 2.125V when the computer is booting up.
D3h
2R5-E1V voltage is not less than 2.125V when the computer is powered off.
D4h
2R5-E1V voltage is not more than 2.125V when the computer is suspended.
In the case of error code 10h or 12h:
Make sure the AC adaptor cord and AC power cord are firmly plugged into the DC IN 15 V socket and wall outlet. If the cables are connected correctly, connect a new AC adaptor and/or AC power cord, if necessary.
In the case of error code 2Xh:
Make sure the battery pack is correctly installed in the computer. If the battery pack is correctly installed, replace the battery pack with a new one.
If the error still exists, the system board or the battery board may be disconnected or damaged. Disassemble the computer and check the connection between the AC adaptor and the system board and connection between the system board and the battery board (if there is one, in my case it was integrated to ths system board).
After checking the connection, perform the following:
Check 1
Replace the AC adaptor with a new one. If the AC adaptor is still not functioning properly, perform Check 2.
Check 2
Use a multimeter to make sure that the F8800 fuse on the System board is not blown. If the fuse is not blown, go to Check 3. If the fuse is blown, go to Check 6.
Check 3
Use a multimeter to make sure that the F1000 fuse on the Battery board is not blown. If the fuse is not blown, go to Check 4. If the fuse is blown, replace the Battery board with a new one following the instructions in Chapter 4.
Check 4
Make sure that the Battery board cables are firmly connected to PJ8820 and PJ8821 on the System board and to PJ1000 and PJ1001 on the battery board. If they are connected firmly, go to Check 5.
Check 5
The Battery board or System board may be damaged. Replace it with a new one following the instructions in Chapter 4.
I hope this helps many people with the troubleshooting. Details may vary as models vary, but most if it is the same for every Toshiba
Mar 03, 2017 | Toshiba Tecra M10 Notebook
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
Sony viao wont boot, battery light flashes amber once when power button is pressed, AC power indicator on laptop is green and responds to being un-plugged and the adapter LED is green,but it still wont...
Move the power jack around while plugged in, does the blinking on the battery stop when you hold it in certain positions? If so, your dc-jack needs to be soldered, but i probably was loose already before you started using it. It could be a broken motherboard issue as well. You can try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
Jan 17, 2010 | Sony VAIO VGN-N325E Notebook
Toshiba Qosmio G30-188 Laptop DC Car Adapter (15V/6A 120Watts) by Amstron (Generic) Logo
372 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
