Can i get the code for Implementing stellation and rosettes using openGL along with the discription
How can i corredt this error ??
report to mojang and play the pe version for a while. or you can delete your minecraft file and download it again
May 23, 2014 | Kaltner.net Minecraft Mobile Admin
Project on OpenGL
http://nehe.gamedev.net/lesson.asp?index=01
There are the best set of lessons for OpenGL beginners.
May 21, 2009 | Advanced Graphics Programming Using OpenGL...
I want a program in openGL for the paint editor
i want a mini project on opengl the topic is graphics ediotor jst like ms paint
May 20, 2009 | Advanced Graphics Programming Using OpenGL...
I need open gl source code to make a point move along the circumference of the circle.
Hi
 I'm studying Physics, not CS, but I've had a few brushes with OpenGL.
 I'll use a Basic-like pseudocode syntax since I don't know what language you're using, and basic is very easy to read:
'Constants - Radius is radius of the circle
Const PI = 3.14159, Radius = 10
'Current angle, and angular velocity (dTheta / dt)
Dim Shared Theta as Single, Omega as Single
'Frame is called when you want to draw a new frame
Sub Frame(dt as Single)
  'dt is number of seconds passed since last frame (typically less than one, since you want several frames per second)
 'Initialize the frame (clear buffers, set up projection, etc)
 InitFrame
 'Increase angle
 Theta = Theta + (Omega * dt)
 'Calculate co-ordinates of point
 X = Radius * Cos(Theta)
 Y = Radius * Sin(Theta)
 glBegin(GL_POINTS)
  'Set the colour of the point
  glColor(<r>, <g>, <b>, <a>)
  'Draw the point
  glVertex2f(X, Y)
 glEnd()
 'Display the frame
 RenderFrame
End Sub
May 16, 2009 | Advanced Graphics Programming Using OpenGL...
Opengl code
OpenGL doesn't handle photonics or any other low-level physics - you'll either need a raytracer, such as POVRAY or Blender, or you'll have to write the physics yourself, to emulate light rays of varying colours (I recommend using a HSL colour space for your physics, only translating to RGB when rendering the frame).
The refraction of a ray at the interface of the prism and the "air" can be calculated using Index of Refraction, correction factor to account for different refraction dependent on frequency (Hue) and a random number generator to emulate slight scattering.
Apr 24, 2009 | Advanced Graphics Programming Using OpenGL...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
