Question about Ecoray 112DX Version 2 LED Reef and Aquarium Light
My fish tank has a canopy . And it has a minimum room can they be attach to it or they must be hanging ?
Can the Marina i25 be used in a small saltwater aquarium?
: You could but a few shrimps is all you could keep in there and it would be a very small marine tank .An experienced fish keeper could mange that but i always advice 30 gallons minimum for starting a marine tank .
Jul 27, 2015 | Fish
How do i replace fuel filter 2005 softail fxst
Disconnect the negative battery cable
Remove the seat
Remove the T27 Torx screw securing the front of
the console to the fuel tank.
Remove the two T25 Torx screws and washers securing the rear of the console mounting bracket to
the frame.
Lift the console partially up off the fuel tank, and
disconnect the electrical connector from the ignition switch, the indicator lamp and speedometer.
Remove the reset switch from the console.
Carefully remove the console and lay it upside
down on shop cloths or towels.
Remove the rubber boot from the odometer reset switch on the left side.
Remove the acorn nut and washer securing the console to the fuel tank.
On fuel injected models, disconnect the fuel pump electrical connector.
Lift the console partially up off the fuel tank and lay
it upside down on shop cloths or towels.
Unhook the ignition switch harness from the clip on the side of the console.
Disconnect the electrical connector from the ignition switch the speedometer and the indicator lamp assembly
Remove the odometer reset switch from the left side of the console.
The fuel pump and filter assembly is located inside the
fuel tank. This assembly is part of the removable canopy
attached to the top of the fuel tank. The canopy provides
easy removal and installation of the attached components
without having to work within the fuel tank cavity. An inlet screen on the fuel pump and the secondary fuel filter
canister are located downstream from the fuel pump to
provide maximum filtration before the fuel reaches the
fuel injectors.
Jul 14, 2014 | 2005 Harley Davidson FXST - FXSTI Softail...
2003 harley fl fuel tank gasket top plate torque specifications
While pushing down on the canopy, align holes in canopy
with those in fuel tank. Hand start ten new T20
TORX screws in perimeter of canopy. Tighten screws to
18-24 in-lbs (2.0-2.7 Nm) using the pattern shown in the figure below.
Jul 13, 2014 | 2003 Harley Davidson FLHTCUI Electra Glide...
Can't fit remote receiver into canopy of Hampton Bay ceiling fan.
Hang the fan and slip the receiver between the space above the hanging ball on the fan. Hunter remote might not work.
Mar 15, 2013 | Dryers
Can not get my pet **** out of the tank
Fuel filter attached to pit-caulk swells up with age. Most of the time ruining filter that is replaceable. After nut has been loosened all-of the way, pull down twisting to remove from tank. Add new screen filter, will fit threw tank- pit-calk- hole with room to spare. Helps having empty fuel tank to keep from fuel spill. Or just work fast on cold engine then clean up spilled gas with rag! No smoking ! No sniffing of gas soaked rags! No problem Ha! Ha!
Nov 11, 2012 | 2001 Harley Davidson FXDWG Dyna Wide Glide
What is the difference between a canopy bed and a four poster bed?
A canopy bed is decorative and has 4 posts connecting with fabric hanging from them.7_18_2012_2_55_42_pm.jpg
May 30, 2012 | Furniture
I need assembly instructions for disney princess
Use the hardware that comes with the Disney Princess canopy package to install the main canopy hook in your ceiling. Center the steel ceiling hook above the center of the twin bed and screw it into the ceiling by hand or with pliers. 2 Follow the included instructions and insert the four poles into the sleeves of the canopy. The two longer poles will run lengthwise above the bed, while the two shorter pieces will run widthwise above the bed. 3 Attach the canopy to the ceiling hook by slipping the plastic ring of the canopy onto the hook. The four polyester sides of the canopy should now hang over the twin bed. 4 Use the customer support form through the Exxel Outdoors website if you have questions regarding your Disney Princess canopy.
  • Jul 10, 2010 | Princess International Nursery Crib Bed...
    How to replace fuel filter on harley davidson 02 road king
    I am having problems viewing the reply but if you have a FLHRCI then to replace the fuel filter you will need to be prepared to put some time into it.
    First remove the console off the fuel tank, one nut below speedo and the phillips screw lower close to the seat. You will have a disconnect on the top left side of the fuel tank to disconnect. Then disconnect the vent tube from the tank with a gentle pull & twisting motion. Now the fun part there are ten torx T20 screws you need to remove, but first you must go buy new ones along with the gasket and fuel filter kit. DO NOT reuse the screws. Now for whatever reason they call this piece a canopy, go figure. Once you have your parts go ahead and raise the canopy slightly and twist it to the left a little. Now this can be tricky because there is a spring loaded hng to work here, be care not to over stress any thing. Then you can begin to pull the canopy and components from the tank. You will be limited by the convoluted tubes (hose) attached as to how far you can raise the canopy, if you remove one be careful as where they attach is plastic and breaks....easily sometimes, then you need a $350 part.
    Next read and look at the diagrams that come with your new fuel filter to install it. Once done carefully reverse the canopy removal process and tighten the canopy bolts in cross pattern o somewhere between 18-27 in-lbs. Hope this helps.
    JP
    Jul 25, 2009 | 2002 Harley Davidson FLHRCI Road King...
    What is the height of britannia omaggio 90 cooker hood?
    Here are the dimensions that relate to your cooker hood. The measurements are in mm.
    Width 980 front 578 rear
    Depth 480
    Minimum height 1015
    Maximum height 1170
    Main canopy height 750
    (excl chimney)
    Chimney section width 436 main body/340 sliding section
    Chimney section depth 170
    Mounting height 650 - 750
    Regards
    Alan Hood
    ami-man
    Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
    Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
    Jun 16, 2009 | Kitchen Ranges
    Ecoray 112DX Version 2 LED Reef and Aquarium Light Logo
    Top Ecoray Fish Experts
    Richard Lindsey ...
    ThothMer
    ThothMer
    Level 1 Expert
    Tom Chichester
    Are you an Ecoray Fish Expert? Answer questions, earn points and help others
