Question about Pioneer Audio Players & Recorders
How to reset pioneer remote control axd7500
Remote control will not work receiver,when pressing button on remote display on remote reads rcv/main
  • 4 Answers
SOURCE: universal home theater remote for Pioneer VSX-305 audio/video stereo receiver
Don't spend a lot of money for a universal remote. Radio Shack has some good buys. I think you are the same person who is having problems with a 305. Get rid of it. You can make a quantum leap at Amazon for less than $200 for a Pioneer.
Posted on Jun 12, 2008
SOURCE: Pioneer VSX-1018AH-K 7
Check if Zone 2 is 'On' if it is set it to 'Off' using the front panel button. Hitting the 'Recieiver' and 'Setup' buttons is the correct way to set the system up.
Posted on Oct 19, 2008
  • 36 Answers
SOURCE: Lost remote controller of Pioneer VSX-D506S
You can buy Original Pioneer Remote from HERE for VSX-D506S
Posted on Feb 10, 2009
  • 336 Answers
SOURCE: Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Posted on Feb 13, 2009
smarthome2
  • 1114 Answers
SOURCE: Anyone have the remote control code number for the Pioneer VSX515 receiver?
Are you trying to progam another remote to control your Pioneer? If so, check with www.remotecentral.com if it's available, it's there!! Hope this helps
Posted on May 22, 2009
I have a new onkyo rc 868m remote that seems to have lost its code. can you help me
Hi James, I am sorry that you are having an issue. I do not know your receiver model number but you can try a couple of things. It really did not lose it's codes. If you are trying to control the receiver look for the RCV button on top or the receiver mode button, press that first and then the button you want to use. If that does not work go into the receiver's programming and look for remote control. Check if the remote code is set to 1. Change it if you need to and test. You can change the remote code in the remote. You may have done that by mistake. Follow the instructions in the manual to reset the remote. It will go back to 1. Thank you, Onkyo USA
Nov 13, 2016 | Onkyo Audio Players & Recorders
My pioneer sx-316 multi channel receiver is off on protected mode what do I do to restart
I read the instructions perhaps slightly differently perhaps. I take the instructions to mean first hold down tone and then hold standby/on key for three seconds. Have you tried doing it as two steps?
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the  STANDBY/ON button for about three seconds.
3 When you see 'RESET?' appear in the display, press the ENTER button. OK? shows in the display.
4 Press SETUP to confirm.
Feb 03, 2015 | Pioneer New Original SX316S Remote Control
How too reset pioneer 4800
Check page 69 of the manual :
Resetting the main unit
Use this procedure to reset all the receiver's
settings to the factory default. Use the front
panel controls to do this.
2 While holding down the BAND button,
for about two seconds.
3 When you see RESET? appear in the
display, press 'AUTO SURROUND/STREAM
DIRECT'.
4 Press 'STEREO/A.L.C.' to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory settings.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-819H_OperatingInstructions0508.pdf
Jun 15, 2014 | Pioneer VSX-819H-K A/V Receiver
Pioneer vsx-32 won't turn on with remote
Hi, since both remotes suddenly fail, I am assuming the problem is more than likely with the received rather than the remotes.
If you do wish to check your remotes, then point your mobile phone camera at the remote's Infrared lens and press one the remote's buttons. Your mobile phone camera is able to detect Infrared light and in case you remotes are working properly, you should see light coming out of your remote's Infrared lens.
Make sure that no direct sun light is on your receiver because that can effectively block out the signals from your remote controls.
Try the following method to reset your receiver. Unplug your receiver mains cable from the mains wall socket; power your receiver on by pushing the on/off button (nothing will happen obviously) and leave it like that for say 30 minutes. By that time all capacitors in your receiver will have discharged. Plug your received mains cable in the mains wall socket.Push the receiver's on/off button and see if it know responds to your remote controls.
If the problem still persists, you may have a failed Infrared receiver LED. That component can be found inside your receiver. It will take some basic elelectronics skills to get this component replaced. A service manual can help you. You can download it for free from this website: http://elektrotanya.com/pioneer_vsx-32_33.pdf/download.html
Good luck.
Jan 20, 2013 | Pioneer Elite VSX-32
Hi: i have a sc-05 pioneer elite rec. i just
Hello I believe you are correct in the cause of this problem; it would be due to one of the audio calibration protocols that are programmed on board that uses each channel individually and disables the others. Or, there is one other cause. I'll address both.
Make sure the MCACC microphone is disconnected.
Then make sure the slide switch on the remote is NOT on the selection at the far right that is labeled "RCV." Select either "source", or "TV."
Otherwise, also on the remote is a button on the right side of the panel labeled for channel level as "CHLevel" that allows you to have individual volume control of each speaker.
To correct this, move the slide switch on the remote to "RCV" and then press the "CHlevel" button, then use the left or right arrow keys on the remote to set each channel to the same value. When finished, return the slide switch to "Source."
Jan 10, 2012 | Audio Players & Recorders
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Sep 08, 2011 | Pioneer VSX-819H-K A/V Receiver
I have a Pioneervsx-1021k AV Receiver and all the buttons were working fine until I decided to play with the remote. Now some of the buttons light up, and some don't. I have found that not being able...
Hello
Just reset the system and try. So many external commands may confuse the system control IC inside, will hang up very like our computer systmes do. Resetting it to factory settings will make the unit work well. To reset the system:
Disconnect the iPod and USB memory
device from the receiver beforehand
1# Switch the receiver into standby.
2# While holding down ENTER on the front
panel, press STANDBY/ON.
The display shows RESET .
3# Select 'RESET' using PRESET then
press ENTER on the front panel.
The display shows RESET? OK.
4# Press ENTER to confirm.
receiver has been reset to the factory default settings.
Note that all settings will be saved, even if
the receiver is unplugged.
If this process does not help you, your system needs service with its main system control circuit. Actually this is a very skilled job, and should be done either by any well experienced service technician or by the Authorised Service Center for Pioneer at your town. OK.
Aug 21, 2011 | Pioneer VSX1020K Receiver
I have a VSX-1015-TX ,I powered it on but have no control from either the remote or the receiver itself,changed remote batteries,unplugged/replugged in receiver still no control,the receiver works as all...
to complete reset, it need pressing couple buttons by combination. if all buttons mulfunction, no way to do this function. does unit have front panel display?
Mar 19, 2011 | Pioneer VSX-1015 Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
3 When you see RESET? appear in the display, press ENTER .
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
Re: Remote Control Brand: Pioneer Model: XXD3086 I'm trying to set-up my remote control to my TV and I can't because I lost the instruction book. Please help me with the...
Pioneer remote XXD3086:
1. While pressing the Receiver button, press and hold the 1 button. LCD shows SETUP.
2. Press the Milti Control button for the component you want to control. LCD displys the component (for example, TV/Sat).
3. Use left and right cursor buttons until the LCD displays Preset. Press Enter to select Preset.
4. Use up and down cursor buttons to select the first letter of the brand name of your component. Press Enter. For example, select P for Pioneer.
5. Use up and down cursor buttons to select the manufacturer's name from the list. Press Enter.
6. Use up and down cursor buttons to select the proper code from the list. DONT press Enter yet.
7. Try out the remote control. For example, switch the component on or off by pressing Source. If it doesn't seem to work, select the next code in the list (if there is one).
8. Press Enter to confirm. LCD displays Ok.
VSX-915 model only:
Instead of selecting Preset above, select Learn. Point the two remotes at each other, press the button that will be doing the learning, press the corresponding button on the other remote that is teaching. Press the Receiver button to exit.
Apr 27, 2008 | Pioneer DVR-107D DVD±RW Burner
54 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
