Question about Singer 9960 Quantum Stylist Sewing Machine with Quilting and Sewing
Singer 9960 jams and bobbin case slides
Jams and bobbin case slides
5 Suggested Answers
chrismyers67
  • 53 Answers
SOURCE: how do i replace the bobbin case in singer machine
When you insert the bobbin case, make sure the "knub" on the bobbin case (#1) is just to the left of the position finger bracket (#2). It should sit in there nicely and you should be able to spin the hand wheel freely.
Let me know if you need more help,
Chris
Posted on Jun 07, 2010
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
zlana91
SOURCE: My bobbin case came out
I just had this same problem and although i could not find the answer online, I managed to fix it.
If you look at the bobbin case there are 3 different tabs sticking out.
First you need to have tab #1 under the main part of the machine, and #3 over top of the small twisted metal piece below the bottom fabric gripper.
The hard part is to get the second tab into the proper spot. I circled the piece that you need to move in red. If you move the little piece by pushing it with a flat screw driver, you can line up the bobbin case so that tab #2 is under the metal piece and the bobbin case will be properly set.
Don't give up! It wasn't easy to get it back but I did it, I'm sure you can too!
Posted on Sep 06, 2012
  • 61 Answers
SOURCE: my singer quantum stylist 9960 bobbin case squeaks while sewing the stitches are fine its just sounds terrible
Oil it! Put a drop of oil on everything hat moves every eight hours of operation," except plastic gears etc". Use only Singer oil on Singer machines. Plastic gears require a grease made from plant.. "Do not use petroleum based oils or grease on your machine,it will dissolve the plastic gears etc". used in your machine..
Posted on Nov 13, 2013
Testimonial: "but the manual says do not oil this machine"
My automatic thread cutter jams in the bobbin and will not cut thread. Everything else wotks fine. This is a singer quantom 9960, have had less than a month.
If it's a new machine, you may be able to take it back to the vendor. Otherwise, it is probably covered under warranty.
Mar 14, 2017 | Singer Sewing Machines
New 9960 Singer sewing machine keeps jamming
try a new needle-- one for the fabric your sewing
make sure the top thread doesn't come off the thread take up lever
make sure the bobbin is inserted correctly
if the suggestions don't help
take the machine back and tell them what it's doing and ask for another one
Mar 05, 2014 | Singer 9960 Quantum Stylist Sewing Machine
New 9960 sewing machine keeps jamming
try a new needle--the correct one for the fabric and thread
make sure the top thread has not come off the thread take up lever
rethread the machine top and bobbin-- using every thread guide
make sure the bobbin is turned the right way in the bobbin case
if these suggestions don't help, then taking the machine to be checked would be a good idea.
I have a Singer 4562 T sewing machine. When I try to sew the bobbin case is jumping out of the housing. With the slide closed I sew until everything gets a mess on the underside. When opening the housing...
pl open the entire bobbin housing two scrwes with suitable screw driver and clean .test the latch on the bobbin case,look for steel tension strip screw replace the unit ,also replace needle
Dec 11, 2013 | Singer 7442 Mechanical Sewing Machine
How to remove the screws holding needle plate on singer 9960
Hi Mary Lou.
Just wanting to confirm the machine you are talking about is the Singer 9960 as shown in the link below.
http://singer9960.org/
Jun 19, 2013 | Singer Sewing Machines
What size bobbin to use on 9960 model singer
Your Singer 9960 uses Style 15J bobbins, they cost around $1.50 each. You can get them at most Fabric Stores, Ebay and Amazon . You have a great sewing machine enjoy it and have fun. Good luck
Aug 20, 2012 | Singer Quantum 9940 Computerized Sewing...
How to replace the bobbin case in a SINGER MODEL 5160 sewing machine
On my old school singer it slides in kinda diagonally n not always easy to get in if your pushing at the wrong angle.
Jun 13, 2012 | Singer 5160 Mechanical Sewing Machine
Just purchased a singer Quatrum from hsn 9960 style i need exact instructions on bobbin winding a video maybe
Hi you can download a free manual from Singer.
http://www.singerco.com/accessories/manuals.html
Just type in 9960 in the search box and click on search.
It should give detailed instructions on winding a bobbin.
If this does not help, try this video from youtube:
http://www.youtube.com/watch?v=DlrTnW_FUqA
Aug 31, 2010 | Singer Quantum 9940 Computerized Sewing...
Singer 9960 Quantum Stylist Sewing Machine with Quilting and Sewing Logo
32 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
