Question about Asrock Computers & Internet
Accession of LED connector for P4V88
Exact position of the Accession
Asrock p4v88 9 beeps
http://pcsupport.about.com/od/fixtheproblem/tp/ami-beep-codes.htm
THE MOTHERBOARD HAVE GIVEN YOU THE CODE OF
CHECKSUM ERROR.TRY CLEAR CMOS IF THAT NOT HELP
THE MOTHER IS IMPOSSIBLE TO FIX.
Feb 15, 2014 | Asrock P4V88 (P4V88 RAID) Motherboard
Pci and audio drivers
Download the drivers here:
http://www.asrock.com/mb/VIA/P4V88/?cat=Download
But first select your windows system.
Good luck
Jan 05, 2012 | Asrock P4V88 (P4V88 RAID) Motherboard
Does asrock p4v88 motherboard support low and high density?
Hi, you can download a user manual here:
http://www.asrock.com/mb/manual.asp?Model=P4V88
Here you also find drivers.
And remember to select your operating system.
Please unzip the file before installation.
Aug 29, 2011 | Asrock P4V88 (P4V88 RAID) Motherboard
I have an asrock p4v88 mb with 2gb mem and am trying to install seagate baracuda 1 tb hd bios says drive not detected any answers vern
Try to upgrade your drivers for the mainboard
from here:
http://www.asrock.com/mb/download.asp?Model=P4V88
Remember to select the windows you are running.
Upgrade the 4 in 1 driver first, and the SATA RAID Driver.
Hope this solves your problem.
Mar 21, 2011 | Asrock P4V88 (P4V88 RAID) Motherboard
Asrock P4V88 SATA RAID 1.5 Windows 7
No drivers for windows 7, here at the homepage:
But try the VIA drivers from here:
http://www.viaarena.com/drivers.aspx
This mainboard will probably only only run the 32 bit system.
Good luck
Feb 12, 2011 | Asrock P4V88 (P4V88 RAID) Motherboard
I want raid driver for asus p4v88 motherboard. ( win xp )
hey here. copy the link below and click for your desired driver.
just choose from the sites were you want to download your driver.
http://www.asrock.com/MB/download.asp?Model=P4V88&o=XP
hope this helps..
Good day.. :)
Jan 29, 2011 | Asrock P4V88 (P4V88 RAID) Motherboard
Drivers for windows 7
Hello try the via homepage here:
The mainboards homepage, only supports windows xp:
Best of luck
Oct 11, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
Dual channel Mode willnot work over 2 gb's of
Hi, please read page 12, section 2.3 in your manual. Dual channel memory must be connected per manual specs.
(Correct colored DIMM slots)
Link to Asrock manual; ftp://174.142.97.10/manual/P4V88.pdf
Main web site provided by Asrock; http://www.asrock.com/mb/overview.asp?Model=p4v88
Once the memory is installed into the correct colored DIMM slots your system should see up to just under 4GB if 4GB is installed while using windows XP. (Refer to Asrock's web site).
Hope you find this helpful and working.
Mike
Aug 01, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
Computers & Internet Logo
10 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
