Question about Electrolux EL8502 Versatility Bagless Upright Vacuum
Belt pulley not moving - Electrolux EL8502 Versatility Bagless Upright Vacuum
Could it be the switch?
Posted on Jan 24, 2016
How to tighten pulley on Hoover U6630-900
I'm not sure what you mean by "Common Pulley". There is a flat belt that goes from the motor shaft to the big round pulley on the transmission. There is also a "V" belt that goes from the transmission to the brush roll. You have to be careful how you install the "V" belt because it has a pulley that takes the slack out of the belt when you pull the handle back if you have the lever in "Carpet" position. The belt does not get tight until you pull the handle back which leads many people to believe the belt is too long or the pulley is not working properly.
Jun 04, 2016 | Hoover U6630-900 WindTunnel Bagless...
Brush wont move and its not the belt
If the belt is not broken, most likely the brush roller needs replacing. If the brush roller turns freely then it is likely the pulley on the motor that drives the belt.
Oct 03, 2014 | Proteam ProForce® 1500XP Bagged Vacuum
How to install leather belt on Singer treadle sewing machine?
The belt is a round leather belt and is joined by a wire staple. It passes over the pulley on the hand wheel, down through the slot in the table and a slotted plate goes into the table slot with the belt in the plate slot. The belt is than placed against the big pulley, turn the pulley and a lip on the pulley will pick up the belt and feed it into the groove of the pulley - that's it! (If the belt is too long, cut it to the correct length, pierce a new hole in it and feed the staple into the hole).
Apr 01, 2011 | Singer Vacuums
I need to replace the belt. Have the belt and the vacuum bottom off. What do I attach the belt too?
This unit has 2 belts. The V-belt on the brush usually doesn't cause problems. The larger flat belt requires regular replacement ( belt # 38528-035 ). The belt is first placed around the motor shaft toward the rear of the machine, and then around the large pulley. You must have strong fingers to stretch the belt over the drive pulley. Start the belt at the top of the pulley, and try to "roll " it around the pulley a little at a time, holding the belt firmly around the pulley as you go.
Feb 21, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Eureka 4870: Brush roller turns even in hose setting.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
Jun 21, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
New main belt alignment for Hoover Windtunnel Mach 6.1. Belt moves 1/4 inch towards of vacuum cleaner and will not stay aligned on the V convex guide pulley
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=853508
Generic problem for all Vacuums
Posted by donlee300 on July 29, 2008
Belt moves 1/4 inch towards of vacuum cleaner and will not stay aligned on the V convex guide pulley.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is possible that you may have a broken or cracked motor mount and the motor has shifted and that could be the reason that the belt is not running straight and aligned properly – if you have the vacuum less than one year – something like this would be covered under the Hoover factory warranty and to contact an authorized Hoover vacuum cleaner dealer in your area or to call the Hoover factory cust serv @ the phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 29, 2008 | Vacuums
Install self propelled belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=647063
Posted by wmtp on Jun 04, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually the self propelled vacuum have 2 belts and you should replace them both 2 the same time 1st the self propelled belt and then the brushroll belt. Normally you would hook the belt on the pulley side of the brushroll or self propelled unit and then stretch the belt onto the motor pulley side of the motor using a belt puller or a screwdriver with a bend on the end for pulling and or stretching either belt onto the motor pulley. If you have a problem please feel free to contact your local vacuum cleaner dealer.
Go Ahead. Use Us.
Jun 04, 2008 | Vacuums
Hoover windtunnel
Put the V belt on the pulley first, then the flat belt, put it over the motor shaft or pulley, then you have to stretch it to go over the pulley next to the V belt pulley.
Jan 18, 2008 | Hoover U6616-900 WindTunnel Bagless...
Electrolux EL8502 Versatility Bagless Upright Vacuum Logo
44 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
