I have a edward pearson shear and the cybeklec dnc 60 gs controller screen is flashing green.?
2010 60 inch flat screen stuck on welcome screen has flashing green power button
Check that you have other operating channels. This may indicate that your tuner board is not working, and that you cannot process channel signals for your TV. Likely you have adequate power if the LED is green.
Feb 09, 2015 | Televison & Video
Mylab mastering
uninstall program then try it again
Jan 18, 2014 | ASUS Computers & Internet
Blinking green light
It is likely that the power supply is failing. It tries to start and powers up briefly then shuts down.
Oct 28, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Green flashing light
the green flashing light does not make sense if set is working.
As far as a dark picture if lamp not replaced or replaced with a generic it may be nearing the end of its life, many will dim just before failing.
Dec 05, 2012 | Mitsubishi WD-60737 60 in. HDTV
What type of antifreeze is best for my 2001 Jeep Grand Cherokee? (I just bought it few months ago.) Thanks, Edward
Edward. the recommended antifreeze is the MOPAR antifreeze. I think the additives are the reason that you want that antifreeze.
Jan 21, 2011 | 2001 Jeep Grand Cherokee
Screen turns black, sound continues, green light flashes, picture returns, green light steady, repeat
Bad Lamp replace it Part# XL2200U Fox has for $109.00 1-800-227-5369 other company I Checked with wants $215.99
Dec 08, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
Sep 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Green and orange light flashing
Assuming there is no paper jammed, turn off printer and disconnect from usb port. Go to add/remove programmes and uninstall printer software and drivers. Go to printer and faxes folder or go through control panel and ensure the HP printer is deleted, if not right click and delete. Re-start pc and install drivers from your printers cd rom and re connect printer when prompted and not before (if no prompt when software finishes connect printer). Your pc should then idenitify your printer and auto install drivers. If the lights still flash then there is a hardware problem, probably not worth repairing, as printers are so cheap nowadays.
Jan 07, 2007 | HP DeskJet 3820 InkJet Printer
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
