Question about Acer Veriton 3600G PC Desktop
To configure the BIOS again with the Date and Time
My system time and date is not set
Go into the BIOS settings then to the Date and Time and set the Date and Time, Save the settings and Exit.
IWhen you boot up later and the Date and Time is incorrect then the BIOS battery is flat and a new replacement battery is needed. The BIOS battery keeps the laptop's configuration plus the Date and Time settings unless the battery is flat.
Apr 16, 2012 | Dell Inspirion Computers & Internet
How to set date & time
To set the Date and Time on your computer - go into the BIOS configuration then to Date and Time to set the correct Date andTime.
If the Date and Time needs setting up again after to boot up the computer again, then the BIOS battery needs replacing because the old battery is flat and cannot maintain (store) the Date and Time.
May 19, 2011 | Computers & Internet
Date problem
When the Date and time error message comes up during booting up the computer, it means the BIOS requires configuration.
If this occurs every time you boot up your computer after changing the Date and Time then, this is caused by a flat BIOS battery.
The BIOS battery is ususlly a 20mm dia. 3 volt lithium battery type CR2030
Replace the BIOS battery and then configure the Date and Time and you won't get this error again.
May 14, 2011 | Computers & Internet
Please run setup invalid configuration information
If this error message comes up when you boot up the computer, it means the BIOS requires configuration, usually the Time and Date is wrong.
If this occurs every time you boot up your computer and have changed the Date and Time then this could be caused by a flat BIOS battery.
If so, replace the BIOS battery and then configure the Date and Time and you won't get this error again.
May 14, 2011 | Dell INSPIRON 6000 CENTRINO...
Soon as it start up its says RTC mode fixed- Time and date may be wrong. then its says time-of-day clocked stopped and it want let me go anywhere from there.
When you get this message you need to go to the BIOS configuration to change the date and time setting.
If this happens again when you boot up later, then the BIOS battery is flat and needs to be replaced because it cannot save and retain the BIOS settings.
Jan 19, 2011 | Dell Inspiron 1200 Notebook
I have a Gateway laptop model no. M622-UCX which continues to prompt for the system date configuration in cmos setup during start. It also cannot remember the date and time I entered several times and...
When a laptop/computer prompts for a BIOS date and Time setting every time you boot up, this indicates the BIOS battey is flat or nearly flat. This BIOS battery needs to be replaced and the BIOS Date and Time setting needs to be configured etc.
Mar 14, 2010 | Gateway Computers & Internet
Just bought this Samba 1845 system. Upon power on receive bios rom checksum error, insert system disk. Is the battery dead, bios need to be flashed again, please help
A BIOS sum check error is usually due to a near flat BIOS battery.
Replace the BIOS battery and configure the BIOS Date & Time setting etc.
Oct 27, 2009 | FIC Samba SM-1845 (SM1845GV) Barebone
Lenovo thinkpad R51e ,when i power on the laptop it show error271
This error message is generated when the BIOS Date and Time is incorrect. Go into the BIOS configuration to change the Date and Time. When you reboot and still get the same error message then the BIOS battery is flat and needs to be replaced and the Date and Time setting needs to be change to the current Date and Time after replacing the battery.
If you cannot get into the BIOS configuration (press F1 on bootup) or you get a lock icon in the top LH corner of the screen, this is a Power on Password symbol, enter the passsword to bootup the laptop and then press F1 to get into the BIOS configuration.
Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
TIME DATE LOCK 0271
This IBM 0271 error code means the Date and Time setting in the BIOS is incorrect and needs to be reset in the BIOS configuration.
This is caused by a dead or nearly flat BIOS battery.
You need to replace the BIOS battery and reset the Date and Time.
Apr 08, 2009 | IBM Computers & Internet
Error 0271 check the date and time setting
The BIOS battery is flat and cannot keep the corrected date and time. Replace the BIOS battery anf then go into the BIOS configuration to set the time and date.
Mar 13, 2009 | IBM ThinkPad T20 2647 Notebook
Acer Veriton 3600G PC Desktop Logo
13 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
