Question about LG Dryers
Lg dryer won't stop - LG Dryers
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
LG Tromm Dryer Won't Stay On!
Your motor might be weakened. As when you start is back does it come on if it does then we are looking at venting issue.
Oct 06, 2017 | Dryers
My LG Dryer DLE2301W won't turn on.
you need to get new dryer/ you got short circuit on the motor
Aug 27, 2012 | LG Dryers
Have a DLEX5101V dryer... It won't stop spinning after the timer ends - as long as the door closed it keeps spinning.
if you can get access to your main control board be hind panel. unplug dryer then tap the control board a few times. you could have a stuck relay. plug back in and try it. may fix you problem short term.
Aug 17, 2011 | LG DLEX5101V Electric Dryer
It has yellow bars and is glowing yellow when it stops
Here is a tip that I wrote about why an electric dryer will not stop heating sometimes.
Electric Dryer won't stop heating
heatman101
Aug 07, 2011 | LG DLE2512W Electric Dryer
Lg model #dle0332w dryer won't turn open it up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | LG Dryers
My LG DLE8377WM dryer stop spinning. Turns on fine, smells as though heater element turns on but the tub won't spin. Can hear what sounds like a motor trying to turn.
heatman101
Jun 25, 2011 | LG DLE8377 Dryer
LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Dec 12, 2008 | LG DLG5932W Gas Dryer
Dryers Logo
20 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
