Question about Vacuums
Bissell not working
It is the bissell essential 8852 and it is not spraying out water or solution.
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
reddevil6
  • 1673 Answers
SOURCE: bissel powersteamer clearview will not spray water
Did the gasket on the bottom of the water tank come off and is either missing or sitting in the hole where the tank sits? It needs to be on the tank.
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole, this is for the soap bottle also, there is a seal on the bottom of it as well. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines. Is the top cover and the base tight together in the back, sometimes the top breaks loose and it will raise up and it can't spray, just re-fasten it down.
Posted on Aug 10, 2008
SOURCE: Bissell carpet cleaner won't spray water on floor setting
I have the same problem, can someone help.
Thanks
Posted on Jul 30, 2009
SOURCE: Bissell ProHeat Carpet Steam Cleaner stopped spraying.
The problem was a clogged heating unit which is located in the lower handle. There are two clear hoses going up the inside of the left leg of the lower handle that go to the heater and to the in-line water switch all within the lower handle. I unplugged the metal heating unit water lines and electrical connections (label the connections as you take them apart if you have a hard time remembering things...there were seven connection in all be it water and/or electrical). Removed the heat unit out and then removed the 6 screws holding the heater cover. Inside was a white powdery pasty debris (lime deposit ?) and the water path was clearly blocked in four different places. I cleansed the water trough with a little water and soft toothbrush and several toothpicks then reassembled. If you need new washers go to Orchard or ACE hardware. Take the old rubber washers(they are red) with you for comparison. I didn't need new washers...I just gently cleansed them. I immediately ran clear water through the machine and actually cleaned the carpet with a water rinse only. Will go back and finish the carpet the right way tomorrow. I had only used my machine three times before this happend over a three year period. A friend told me to always rinse it two maybe three times with clear water after using it and before storage. This took me exactly 42 minutes to disassembly and reassemble. Cost savings is several hundred dollars since I have a 5 bdrm house and would need a professional cleaner to do the small dirty traffic lanes all around the house.
Posted on Sep 19, 2009
  • 10 Answers
SOURCE: bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Posted on Sep 26, 2009
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Can't get the water to spray and the red star is not turning
DIY - Fix your bissell if it doesn't spray solution any longer ...
? 5:33
https://www.youtube.com/watch?v=SLyDeM10k9k
Feb 6, 2010 - Uploaded by kronomarine
Common problem with most Bissell Carpet Cleaners is that it stops ... to no one repeats my mistake, this is NOT the Bissel Proheat 2x Turbo Model .... water go back to use 8 months later and now it only sprays water ... I can't understand ANYTHING said to me by the Bissell reps in India or .... Get video URL.
All comments on DIY - Fix your bissell if it doesn't spray ...
Nov 28, 2015 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 9500 spraying solution but not water
Hey, sorry to hear the spray isn't working on your machine.
Here's a quick link to the complete troubleshooting steps for no spray for your machine.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Feb 13, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell proheat2x 8920 wont spray water
Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell stops spraying water, carpet not wet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtetrhgd
May 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat 9500 won't spray water
heatman101
ukyr
Jun 08, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
