Question about Lanier Ld328c Ld335c Ld345c Black Developer Unit
Not want to read the new toner
Change the black toner cartridge with a new one. after several minutes says it has no toner. what should I do?
  • 128 Answers
Very, very common issue on these normally related to a problem in the toner hopper assembly itself.
Posted on Aug 24, 2014
Just replaced black cartridge in my 2600n color laser. I have smudged about a half inch wide 2/3rds over the right of each page. It only smudges in black. I have recalibrated several times. Printed at...
If this just started after you replaced the toner cartridge, one would have to say that it is a bad toner cartridge.
Print something that smudges. Pull down the front cover and look at the cartridges. Pay attention to the top one(black).
Look at the drum on that cartridge. You should see the toner sitting there. Compare it to the other cartridges which should be clean.
Feb 08, 2011 | HP Color LaserJet 2600n Printer
My Canon PC-25 copier is streaking
Toner cartridge is defective - replace it
Apr 06, 2009 | Office Equipment & Supplies
Error Message/Black toner empty
Most all new color laser printers employ an RFID reader adjacent to each of the 4 tomer cartridges. There is a unique RFID chip inside (under a small blue slide cover) each toner cartridge. Whan a new toner cartridge is installed, the printer "knows" such and begins a "countdown" of the number of prints that are made which utilize the toner in each of the 4 cartridges. Once a toner cartridge has "processed" the predetermined number of copies you will get a warning that the cartridge is almost empty and must be replaced. After an additional predetermined number of copies are processed, the integral computer within the printer will shut down the printer until the cartridge is "replaced". If you simply "refill" the same or original cartridge and re-install it into the printer, the same RFID chip is in the cartridge and the computer will not reset the print "counter", allowing you to start printing. You have to obtain another couple of new or "re-filled" cartridges (of the same color or black) from an outside source. The printers' internal computer does not keep a complete running list of all of the RFID chips that have been installed and used in the printer (maybe 2 or 3) and then then it is "1st in / 1st out" of the limited RFID memory of the printer. I have been unable to obtain a "Service Manual" for the OKI C3400n printer to determine how to do a "hard reset" of the internal computer. I know there is a way which would allow the "refilling" of the toner cartridges without having to buy an additional 2 of each color.
Dec 06, 2008 | OKI C3400N Single Pass Color Printer
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
Dell 3100CN w/new black toner cart reads "Black toner LOW"
service your printer and change roller taplon tape and fuser aseembley.
Oct 09, 2008 | Dell 3100cn Laser Printer
Error code 54.18
The error code 54.18 means that there was an error with black toner cartridge toner level sensor. Try taking the cartridge out and shake it a little to loosen up the toner inside, make sure all of the cartridge metal electrical contacts are clean and try it again. If it still has a problem you should try a new black toner cartridge. If that doesn't change things then you may need to replace the DC controller.
Sep 09, 2008 | HP LaserJet 3600dn Printer
CopyCentre C20 Toner Low Stays On
ave you tried shaking the cartridge vigorously from side to side?
The ink may be compacted in one end of the cartridge from storage.
Jun 06, 2008 | Xerox CopyCentre C20 Black and White...
Printer is printing entire page black
  1. clean the cartridge properly.
  2. take the waste toner from waste section
  3. change drum
  4. change chip
  5. do it this i think your probalem is solved
new problem
  • changed black cartridge but print color mixed print out
what i do? send the details to my email
May 14, 2008 | HP Color LaserJet 2600n Printer
HL-4040CN don't show or read new refilled magenta cartridge.
If you have removed and reinstalled the magenta cartridge several times, it is very likely the cartridge is defective out of the box. If you have another magenta cartridge, put that one in and see if the problem resolves. I'm betting it will. If that second cartridge does work, then return the defective cartridge to where you purchased it - they should replace it without a hassle.
May 10, 2008 | Brother HL 1440 Laser Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Lanier Ld328c Ld335c Ld345c Black Developer Unit Logo
51 people viewed this question
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
Anthony Karuku
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
