Question about JVC AM FM CD DET FACE CAR STEREO
Where does orange/white wires go for jvc head unit
I need to no where the dimmer wire goes in a vl 87model car and the orange/white wire
Benimur
  • 6966 Answers
SOURCE: Cd stero wiring help
To my knowledge, the illumination wire need not be connected to the JVC KD-G230. Further, other than the 8 speaker wires, the JVC has only:
  • black - body ground;
  • yellow - always on B+12
  • red - ACC/IGN B+12
  • blue w/ white stripe - external amp trigger and/or power antenna
Perhaps this might be of further help to you.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 17, 2008
shawnsz
  • 64 Answers
SOURCE: i need to no what the wire colors mean on my head unit
hope this helps
http://resources.jvc.com/Resources/00/00/97/49767ien.pdf
Posted on Feb 19, 2009
  • 48 Answers
SOURCE: Wiring problem with jvc radio and Pontiac Montana,
YELLOW WIRE IS CONSTANT, SO YOU NEED TO FIND A CONSTANT POWER SOURCE. GET A TEST LIGHT, GROUND IT, AND TEST THE WIRES WITH YOUR CAR OFF AND KEYS OUT OF THE IGNITION. MAKE SURE IT HAS A GOOD GROUND. LET ME KNOW HOW THAT WORKS OUT.
Posted on Dec 02, 2010
SOURCE: color code for speaker out on a JVC KS R140 car casette player
White - left front
Grey - right front
Green - left rear
Purple - right rear
Yellow - memory power
Blue - remote power (power ant, amp or eq power)
Posted on Dec 15, 2010
  • 32 Answers
SOURCE: Installing Jvc KD-R610 into 02 Nissan Frontier,
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Posted on Dec 27, 2010
HAVE A P05091506AE STEREO WANT TO CHANGE TO A JVC KD-R900 NEED TO KNOW WHAT THE WIRING ON MY 2005 DODGE RAM 1500 PIN CONNECTOR IS. 22 PIN CONNECTOR. COLORS ARE NOT MATCHING ANYTHING I CAN FIND ON...
This is the wiring codes
2005 Dodge Ram 1500 Truck Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Brown/Red
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: Dark Green/Red
Car Stereo Amplifier Location: Located behind the glove box.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 25, 2010 | JVC Car Audio & Video
Need wiring schematic telling me what wires in the harness go where.
red-power wire to power when ignition is on.yellow-battery back-up to powersource that stays live when car shut off.black-ground wire.blue-remote turn on for amplifier.blue/white-power antenna.orange or orange/white-dimmer to make deck lights fade when headlights get turned on.white and grey are your front speakers and green and purple are the rear,not sure about speaker sides though
Jan 10, 2010 | JVC AM FM CD DET FACE CAR STEREO
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 03, 2009 | JVC KW-XC777 CD / Cassette Player
Pioneer Deh-2300
The wiring colors are the same on all major brands of head units it goes a following:
Red: swtiched +12
Yellow: constant +12
Black: ground
Orange/white: dimmer
Yellow/black: cell phone mute
Blue/white: amp turn-on
White:FL speaker +
White/black:FL speaker -
Gray: FR speaker +
Gray/black:FR speaker -
Green: RL speaker +
Green/black: RL speaker -
Violet: RR speaker +
Violet/black: RR speaker -
I hope I could help. Good luck
-Andrew Hawkins
Sep 12, 2008 | Pioneer DEH-P4100
I have a pioneer deh-p44 car stereo and need to know the specifics on the wires.
Red: swtiched +12
Black: ground
White:FL speaker +
Gray: FR speaker +
Green: RL speaker +
-Andrew Hawkins
Sep 03, 2008 | Car Audio & Video
Need color codes and wiring diagram for a 2003 Pioneer DEH-P6500
Red: swtiched +12
Black: ground
White:FL speaker +
Gray: FR speaker +
Green: RL speaker +
-Andrew Hawkins
Aug 20, 2008 | Pioneer Car Audio & Video
Wont keep memory
Most stereo manufacturers agreed on a color-coding scheme for their wiring to keep things consistent. In that scheme, red wires are run to power (ie, the battery) and serve as the ignition-switched power leads (so when the engine is shut off, the head unit also shuts off), black wires are grounds, and purple, gray, green, and white are used for the main four speakers. Blue is an antenna and/or amplifier turn-on wire. Orange is a dimmer wire (for cars with dimmers on the dash lights, this can be tapped in to also dim the head unit's lighting). Yellow wires are typically the memory wires. These feed power to the head unit constantly, regardless of whether the car is on or not, so that memory presets and tone settings are maintained. Your JVC unit should have a yellow wire coming off the back as part of the harness - this would be the one to supply power. You can run this directly to the battery - that way if you blow the fuse in the fuse box that you're considering using, you won't lose your stereo settings as well as whatever feature the fuse was utilized to protect.
Jul 20, 2008 | JVC KD-G320 CD Player
Speaker wiring for a 1993 dodge dakota
To my knowledge a 1993 Dodge Dakota would have the below wiring arrangements for its stereo/head unit:
Constant 12V+ Red/Blue
Switched 12V+ Red/White
Ground Chassis
Illumination Black/Yellow
Dimmer Orange
Left Front (+) Dark Green
Left Front (-) Blue/Orange
Right Front (+) Purple/White
Right Front (-) Brown/Blue
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Red
Right Rear (+) Blue/White
Right Rear (-) Blue/Red
Mar 18, 2008 | Car Audio & Video
JVC AM FM CD DET FACE CAR STEREO Logo
85 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
