Question about Exercise & Fitness
JUSTFITNESS TREDX 1.2 TREADMILL
MY TREDMILL STOPPED WORKING TODAY AND DISPLAYEDN THE word E1
  • 64 Answers
SOURCE: Treadmill runs then stops. E1 error and sometimes works fine.
Yes if speed sensor is too far from magnet it will not pick up belt movement. This confuses the computer and as a safety precaution it shuts the machine off. Find speed sensor and check for proper alighment with magnet.
Posted on Jun 08, 2009
SOURCE: tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Posted on Dec 20, 2009
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
  • 33 Answers
SOURCE: Tuturi J661F stopped working - Error E1
Your problem might be that a magnet has fallen off. Here's an illustrated tutorial that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 33 Answers
SOURCE: treadmill works for 30 seconds and then stops
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Aspire tredmill stops working suddenly and has error message e1
see the detail and fix it.God bless you
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
However test the s.sensor for open and faulty. Clean it, and tigh the connector very well. see the diagram atached.
Jan 21, 2013 | Exercise & Fitness
E1 error. After 15 mins on tredmill
see the diagram. test for open or faulty. clean it and tight the connector very well
God bless you
I have a tredmill that quit.Is there a fuse that could be blown and where is it?
1) Unplug the machine, and test the fuse.
2) See is if there some componenet BURN, such: resistor, diode, capacitor, triac, or SCR. AND tEST IT.
3) See the block diagram, the fuse can be located in the boards, or near to the main switch.
God bless you
Jun 09, 2012 | FreeMotion Emotion Tredmill Tv Treadmill...
SOLUTIONS TO E1 PROBLEMS IN TREDMILLS
Dear Sir:
adjust the speed sensor, clean, and tight very well.see the diagram attached
2) Test the input voltage motor, if there are THE MOTOR need repair
3) Tes the output voltage in the main motor board , if there are Not, the board is faulty.
Of course run the software calibration aftr you fix it.
sincerly. God bless you
Apr 24, 2012 | Bh Fitness X8 Treadmill
I have a HSW1175 Hornet Tredmill which goes for 7 seconds then has a E1 error, please explain???
This conditions is abrupt shutdown of the belt as motor detect a sharp increase a drive currente and inmediately stop driving belt.Ohter situation is jammming the belt, may cause this error.Extreme care and analysis for service technician, required.
E.CUADRA
Nov 03, 2011 | Exercise & Fitness
Stops while in motion
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
May 01, 2010 | Proform CrossTrainer Treadmill
Tredmill not moving
That's an embarrasing admission. A treadmill works like a conveyor belt or a car's fan belt. If it is too loose it will slip under load. There will be an ajuster on your treadmill. All you have to do is tighten the belt. Do not overtighten it though. an
Feb 17, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Hi my tredmill will turn on but moter wont
If elevation will work it's more than likely your motor controller. I would need to know which treadmill you have to help any futher.
Nov 15, 2009 | Exercise & Fitness
Tredmill error code e1
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Exercise & Fitness Logo
89 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
