Question about Mitsubishi Heating & Cooling
Srk71zea s1 The unit shut down with the run button still green but the timer button was flashing yellow now no cool air is coming out and the out side unit won't kick in
  • 81 Answers
SOURCE: The timer light flashes twice about every 15 seconds
This may mean that the filters may need to be cleaned. According to service manual the unit has a "Serial reverse transfer
error at start up operation". Call fujitsu for service if the fault cannot be rectified.
I take the time to answer your questions, please rate me
Mat
Posted on Aug 28, 2009
  • 3 Answers
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Posted on Apr 18, 2010
  • 3 Answers
SOURCE: Toyo Aircon. Starts perfectly. Runs
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
  • 50 Answers
SOURCE: unit not cooling house below 80 HELP ME PLEASE
It's 98 outside ... that says a lot. The gurgling is an indication that you are getting a lot of water out of the air (dehumidifying). If the unit is sized just right, or just a little too small, it may be working perfectly well.
You don't say where you are, geographically, but much to the US has an air conditioning design temperature of 95 degrees F. That means at 95 degrees, the unit will run continuously. With a 50% outside air relative humidity, it should keep the occupied space at about 75 degrees F. The more humid the air, the more the unit works on dehumidifying and less on cooling.
Give it some time, wait unti the weather breaks and see if it doesn't run just like it used to. If you chose to call a technician, have him/her take temperature readings of the condenser entering and leaving air, the suction line temperature, the liquid line temperature, the inside supply and return air temperature (dry bulb and wet bulb) as well as high and low side refrigerant pressures. Before they make ANY changes to the system (refrigerant charge) have them explain what they found wrong and make sure you understand what they are talking about. Adjusting the charge under these conditions, will mess up your operation under normal conditions.
Posted on Jul 20, 2010
hvac1960
  • 2133 Answers
SOURCE: Futitsu Inverter Air-con {ASTA09LCC}- Fan operates
To cancel the timer, press timer on setting until it comes 00.00. Or remove batteries from remote and re fix after few minutes. If still problem persists, check and rectify error code of e-5 as follows:
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Hope helpful.
Posted on Jan 09, 2011
My Kelvinator ESG21HRIA split system blew a fuse in the fuse box and now will not turn on!
to blow a fuse it must have a dead short ( probably vermin across live points)
when thee is a fault in a board (internal and external) it will run then shut down
I recommend that you have a kelvinator service technician come and check ti all out because if the system has been properly installed in the first place ( obviously not from troubles from installation), the units have an operation life span of more than 15 years
Oct 05, 2015 | Heating & Cooling
I have a ruud achiever 90 plus furnace. The blower motor comes on than I can hear the ingniter click one time and the unit shuts down, 1 green ligt comes on than the other gren light comes on than it...
Check the air filter, if its dirty it will short cycle. A clogged drain will also cause the same problem. There should be a printed legend attached to the inside of the unit or cover that gives you the meaning of all the flashing trouble codes. Perhaps yours may be missing?
Feb 07, 2015 | Ruud Heating & Cooling
Fujitsu asta24jcc timer 2 green flashes
The indoor unit has the problem and it's the air thermistor. You need to replace it.
Jan 01, 2014 | Heating & Cooling
A/C runs fine for 7-8 minutes, then shuts off.
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
May 11, 2013 | Sharp Heating & Cooling
The timer light keeps flashing and unit does not respond to the on by cooling the room when the on button is pressed
timer button keeps flashing and no heat coming from unit. cool air works, but absolutely no heat.
Oct 13, 2009 | Daewoo DSA-122L Air Conditioner
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
78 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
