Question about Kenmore 73932 Gas Dryer
Dryer runs fine, no heat.
I have been trying to diag. this dryer but I must be missing something. Performed all related tests, plus. I have no igniter or gas, searching further I suspected the centrifical sw. removed motor assy. disassembled and found a burnt contact on terminal for belt sw. cleaned and checked operation by hand could use more tech data, only thing suspicious gas valve no.2 resistance is 1283 just hair high. Is there more specific tests and data?
SOURCE: Dryer Runs, but NO Heat
The new dryer products clog up the fine mesh screen lint trap. Take it out each time and wash it with hot water until you can see the water run through. I learned this the hard way and paid for a service call.
Posted on Aug 19, 2007
Jimster
  • 240 Answers
SOURCE: Gas Dryer not heating
You will have to replace "BOTH" of those gas solinoids. First, be absolutely sure that you "TURN OFF THE GAS". Then be sure the unit is unplugged. Remove the phillips head screws, remove the small metal top bracket, and slide the coil up and off. Then replace the coil, rehook your wire, and replace the metal holder. Upon testing, be sure to turn your gas back on. The first time it may act like it wont start, but let it cycle through a couple times to remove air. Good Luck And Be Safe. Jim
Posted on Sep 07, 2007
skrbin
  • 121 Answers
SOURCE: Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Posted on Feb 15, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore Elite HE3 Gas Dryer no heat
Verify the glow bar ignitor is working. Also ohm it to specs before you replace a gas valve coil.
Posted on Mar 02, 2009
SOURCE: Kenmore Gas Dryer not heating. (74602)
i have a kenmore dryer the outside air vnet was cloged real bad , ive since cleaned it out but the only resone i found out was becoues my dryer will not heat up , is there a over heat swich ? can any one help .
Posted on Apr 01, 2009
LG DYER MODEL DLG5966W RUNS BUT DOES NOT HEAT, TOOK THE IGNITER IN TO PARTS STORE THEY CHECKED THE CONDUCTIVITY WITH A METER AND SAID THE IGNITER IS FINE? WHAT ELSE COULD IT BE?
Continuity is great but did they perform an ampere test on the ignitor while the ignitor was hooked up inside the unit? An ignitor typically draws between 3 and 3.3 amperes any less then this would constitute a weak ignitor and the ignitor should be replaced if it is weak because it takes much longer to ignite the gas inside a dryer. An ignitor would always show conductivity except if the element were broken. So to start with wrong test was performed. Secondly there are also run thermistors and hi and low limit thermistors that act as relays that can also be checked in dryers by performing continuity tests on these thermistors click this link http://c.searspartsdirect.com/lis_png/PLDM/K0810208-00003.png this is one of the schematics to your dryer k 550 is a thermistor and k 560 is a thermostat both should be tested as mentioned above. M 110 is the gas vavle which on other units the coil is replaceable but is only sold along with the valve on an LG which also has to be tested that power is going to the solenoid on top of the valve and that it is going to the ignitor. If you have any further questions message me back. I await your reply as to any further questions as well as your finds as well. Thanks again
Rick
Sep 20, 2011 | LG D5966 Gas Dryer
I have a problem with my Dell Latitude D600. It only works for a couple of minutes and then freezes up.. is there anything i can do
Two Suggestions :-
1) Test your Hard disk : Restart your Notebook, Go to BIOS Mode and run the HDD Self test
2) Make sure there should not be unncessary programs installed. You can go to start > Run > MSCONFIG and untick the programs you not want to load in your machine. Prefer would be if you uninstll from Add/remove programs.
Please post your feedback and Vote if the problem resolved as per your satisfaction>
Sep 24, 2010 | Dell Latitude D600 Notebook
Im at a complete loss with my dryer. It runs but doesnt heat
Check the 230v very carefully You may be hooking it up even with new wire just like the old. You have to have across the line 230
not just 230. Sounds like you need to have an electrician to check
230 across the line at the wall.
Let me know.
Leo Ponder
imufo2@sbcglobal
Jul 22, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Amana gas dyer wont turn model #lga30aw
Hi.
If the machine stays completely off, does not ignite, does not spark, does not turn, and does not show any sign of power, check the power outlet, and the power cord.
If the machine starts, ignites, but the drum does not turn, then the following parts must be tested:
PS2166310 Motor Switch Kit (part 3 diag 2 )
PS2021298 Motor Assembly (part 5 diag 2 )
PS2046298 TIMER, 4 CYCLE (part 5 Diag 1)
If the Dryer does not ignite or does not heat test the following:
If it does not ignite:
PS2039618 BURNER IGNITOR ASSY (part 7 - diag 4)
PS383994 Two Terminal Gas Valve Coil (p.8 -d.4)
PS383993 Secondary Coil Valve (p.12 d.4)
PS2046673 VALVE,ELBOW SHUT-OFF (p.14 - d.4)
PS2039380 Gas Valve Wire Harness
PS2201082 Limit Thermostat (part 7 - Diag 3)
If it turn but does not heath check also fan assembly and PS2046273 Cycling Thermostat (part 27 - Diag 2)
Here the diagrams
Mar 13, 2010 | Amana Dryers
Heat is erratic
If you already tested the element, then test and eventually replace the following parts:
PS334206
Heating Element Connection Wire part 19 in diag (can be tested using multimeter, check for lose connection or broken wire).
PS347661 Lint Filter , Replace it.
PS383953 and _.gif PS987929 blower assembly (check for obstruction because of lint, and that wheel is working) part 10 and 11 on diag.
PS344510 Cycling Thermostat (can be tested using multimeter), part 8
PS351925 High Limit Thermostat (can be tested using multimeter)- part 15 in diag.
Refer to diagram below to locate parts:
Good luck and thanks for asking us.
G.
May 13, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Gas Dryer SDG515DAWW - heating stopped
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the igniter
a%20igniter.jpg Igniter and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 03, 2009 | Dryers
Kenmore 73932 Gas Dryer Logo
20 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
