Samsung error de1 - Washing Machines
DE1 on the screen of my washer. Did a load of laundry & when I went to open the door, it wouldn't open! Saw the dE1& found out it was for the door. So how would I get rid of the error code
You deleted your post as I was posting my answer to you!
Disconnect from the wall socket for 10 minutes and plug it back in. If that doesn't reset it, hold the ON button for 10 seconds.
That fixed my Whirlpool Duet.
Feb 07, 2016 | Washing Machines
I KEEP GETTING A DE MESSAGE AFTER A FEW MINUTES
My washing machine is displaying an error code ... - Samsung
www.samsung.com/my/support/skp/faq/1033803
Samsung ElectronicsFeb 19, 2014 - ... your Samsung washing machine and the solution needed to resolve the .... If problem persists please call Customer Careline. *. dE. dE1. Ed.
Aug 06, 2015 | Washing Machines
Code de will not go away
You have not included the Make and model of your washer. Below is a google search for Washing machine error code de
This refers to a Samsung washing machine.
I suggest that you edit your question to include both the Make and model number. This question has been answered before on FIXYA for a samsung washing machine. Link included below. dE
dE1 Ed Door issue ·Check that the door is closed fully.
·Check nothing is trapping in the door.
·Check unit is not overloaded.
· If problem persists please call the customer support team.
Samsung washer machine error code dE
Aug 16, 2014 | Washing Machines
De1
check the door lock or the catch on the door
Feb 11, 2014 | Samsung Washing Machines
Samsung error code de1
meand a door error sounds like the lid lock assay is bad
Jan 28, 2014 | Kenmore Elite 45986 Front Load Washer
Hi! Error dE1. Dear, Boris From Russia
Code de1 came up, on my big wash. DE1 means door error code 1, which I think is door not locking. (Judgeing by previous posts). The door didn't electronically lock (clunck), so me and the wife took the top off to have a look inside. Could see the door locking mechanism, (brown plastic) and the orange override manual opener. Turned off power at plug (don't want to electrocute myself) Pulled the orange cord about, that didn't do anything, still error code de1. My wife with slender arms got her arms down there and a connector came off. She could get it back on, so she pulled the drum outof the way, and I got my arm in and put the connector back into its point. (It can only go in one way. So if you have problems, you may be putting it back round the wrong way.) Power back on at plug and it started straight away, door locked and everything seems to be fine, it is now washing away merrily. So it turned out to be a loose connection. Lastly the orange manual override pull, took us ages to put it back, idea, tie a long bit of string to the pull at the bottom, so you can easily retrieve it back down the hole.
Apr 02, 2011 | Washing Machines
De1 error message on Samsung front load washer
Hello,De error refers to "Door Error".
You do not need to buy a new machine. You can fix this.
Look at the below mentioned link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
No doubt the above page is for "LG", However it's the basic and would remain the same for all models and machines whether that's GE, LG, Samsung etc....
Thanks
May 30, 2010 | Samsung WF419AA Front Load Washer / Dryer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
