Nokia 200 format code - Computers & Internet
Where do youput in freon for a/c
you would need a manifold gauge. red hose to high pressure side (bigger fitting). blue hose to low side (smaller fitting). yellow hose to 134a tank. ideal pressure is 40psi for low side max and 200 psi high side
Jun 25, 2014 | 2003 Mercury Sable
Nokia 200 plz give me a unlocked code
You mean the network unlock code?I suggest you can approach Simpleunlocking.com and specify the country,locked network of Nokia Asha 200.Based on the availability you can get the unlock code along with free instructions.
Simple Unlocking Unlock the Nokia Asha 200 mobile phone
Feb 10, 2014 | Cell Phones
Restriction code
nokia asha 206 code please..i tried 12345, 11111, 00000,.. but all not working..
Jan 31, 2014 | Nokia Asha 200 Mobile Phone - Unlocked/No...
I want my restoring security master coda asha 200
RESETTING PHONE NOKIA:Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones
HARD RESET:It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
•Enter the code: *#7370# and press Yes to confirm initialization.
•Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
•To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
•on/off + * + 3
•Before making a Hard reset better backup all your important information: contacts , memo...etc
FORMAT NOKIA:
While my phone if power ON. Press the *7780# code, this code is usually used for the N60 series phone but this code is not working for nokia 5310. And I tried also another procedure again by doing this process:
Your phone must be power off, press the "*" + "3? + "green call key" but nothings happen again I haven't format my phone.
What should I do for this phone, this is able to recognize in the computer and cannot format to hard boot formatting.
My last choice is to find a flash utility cable suits in my phone and the software to re-program it and putting some IMEI codes.
Oct 09, 2013 | Nokia Classic 2700 Cell Phone
How to unlock security code on nokia asha 200
I forgot security code of nokia asha 200. Please tell me how to reset security code.
IMEI 1: 354638057724105
IMEI 2: 354638057724113
waseemwazir1@gmail.com
Oct 11, 2012 | Cell Phones
Nokia 200 henging
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Aug 28, 2012 | Nokia Cell Phones
In my asha 200 no video run?
its simply i have too nokia asha 200 first i shocked too then i search about this matter 3gp or mp4 video both are run on asha 200 many converter make problem when i convert for my nokia asha 200 videos then i use ( amersoft soft video converter) and select from there mobile format in nokia category 3gp fromat its works awesome like mp4 or other formats result is good one
Apr 12, 2012 | Cell Phones
I am having nokia 6300 how to formate my phone i am having 200 songs but in music player i got autorun ink then pl help to solve my pblm. and formate mi phone
Please try this code *#7370# for format whether it's suit for you or not? Regarding your memory card use card reader and attached on your PC and scan anti-virus after that open it and see whether it can open or not? if not format it and use.
or try restoring your factories Menu>settings>restoring factoreis
if not refer to the nearest mobile service centre.
Thanks for using FixYa
Sep 07, 2011 | Nokia 6300 Cellular Phone
How to format Nokia 3110c
The above given does not work it only work on s60 mobiles for s40 mobiles like 3110c, 2700c, 6300 etc.
to format s40 mobile u have to take ur mobile to nokia care they will charge 200 to 250 Ruppes..
i found new way to format the mobile at ur home
http://www.meramobi.info/2010/08/how-to-format-nokia-mobile-phones-3110c.html
Aug 11, 2010 | Nokia 3110 Cellular Phone
I cannot set time and date of my nokia 6270. *#7370# doesnt work
try removing battery for 1 day and then put it back, I think that there is some problem with timer and phone has capacitor inside, so you need to wait until it discharge to reset clock
Jul 11, 2009 | Nokia 6270 Cellular Phone
Computers & Internet Logo
10 people viewed this question
David Payne
David Payne
