Question about Yard Machines 24" 208cc Two Stage Snow Thrower
Loud noise when auger is engaged on 2 stage 24" 208cc
When auger is engaged,the unit makes a loud noise,like missing a gear on a stick shift car when drag racing,or a bad torque converter sound.sound only last a second.I took the belt cover off,and tention pully will not spin easy.this is a brand new unit.model# 31am63fe752
  • 2,049 Answers
If this is covered with a warren tee I would take it back where I bought it. Sounds like a faulty bearing or something is sprung and hitting when it starts up.
Posted on Jan 27, 2015
1995 celica 2.2L doesn't engage gear 2,4,r
are you saying this car is a A/T car, AUTO and not a stick?
say so, as both have 2,4 and reverse gears.
i think its a 5speed manual.
so the tip of the shifter is bad, remove it see plastic parts bad.
you could shift car , by moving the transmission levers and id bet it does work so that leaves. bad shift lever parts.
i bet the lever is real loose , so loose the H pattern is garbage
right> ?
Feb 01, 2014 | 1995 Toyota Celica
Rear auger turns front auger not turning
From your information above, it sounds like a broken gear or tooth on the auger gearbox. (this could happen if you hit an object and your shear pin did not break, instead breaking your gear) Hope this helps.
Jan 25, 2014 | Simplicity I924E 2-Stage Snowblower...
Transmission in chevy silverado 1500 5.3L v8 will not shift from 2-3 gear transmission has been rebuilt and 2-3 shift solenoid was changed but still will not shift from 2-3 gear
For gear shift issues and gear stuck issues,the help links are provided below. Click the link below to go through troubleshooting procedure:---- ---- Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html ---- transmission sticks in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html ----- Transmission not engaging in first gear? http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html ----- Vehicle only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
---- Engine will not go out of park mode? http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html ---- Car stuck in park? http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html ----- Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
--- Car wont downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
---- Transmission will shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
----- Auto wont shift from park? http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html ---- Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
----- Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
---- Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
------- Vehicle has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
----- Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
------ Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
--- Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
------ Gear shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
------- Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
This will help.
Thanks.
Mar 14, 2012 | 1999 Chevrolet Silverado 1500
I lose power and stall when i engage clutch to spin snowthrowing blades on my mtd 24" two stage snowblower. any way to fix?
You probably have a small rock or stick jammed in the smaller throwing auger. Carefully rotate the small auger backwards using a stick/board and tapping with a light hammer till the jamming object pops out. Be careful not to place your hands or fingers in even if it is not running. Worst case scenario the worm gear that rotates the larger auger is broken and jammed and needs replacement. If both augers move freely then you will have to remove the cover under the motor and inspect the belt drive mechanism.
Feb 21, 2011 | Mtd Products Yard Machines 158CC Tiller
Xerox WorkCentre XD100 is making a very loud repetitive noise and in the front door where the ink cartridge is there is a lot of black powder
That means you need to replace both the ink and drum units. What has happened is on the front of the ink cartridge there is a waste sump that has filled up, and in the process has backed up the waster auger in the drum unit. The noise you hear is the auger bowing and snapping from binding .
Feb 26, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
No i did not.trying to find solution problem for transmission not engaging properly between gear changing,i have to speed up to 40 to 55 mph for it to engage. trying to find out why the air condioner does...
Does it feel like it is missing 2nd (shifts from 1-3) or missing 3rd(shifts from 2 to 4th) with the overdrive light flashing. The 5r55w transmission is known for breaking the 3 gear band and the 2/5 band. Also it is known for wearing the band servo pin holes in the case for these bands. The 5r55w has no dipstick, you fill it thru the plug in the bottom of the pan.
May 15, 2009 | 2002 Mercury Mountaineer
Loud clanking noise in gear if the clutch is not engaged
That is what happens when you try to shift gear with out depressing the clutch pedal while changing gears.
May 06, 2009 | 2004 Kia Rio
Yard Machines 24" 208cc Two Stage Snow Thrower Logo
166 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
