Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
My washing machine do not spin
Whirpool
  • 6 more comments
  • Anonymous Nov 23, 2007
    washer will not spin
  • Mario1972 Dec 05, 2007
    I have the same problem. My wirlpool ultimate care II will not spin. Changed the coupling still nothing.Verified the lid switch all good.Then i removed the upper ring around the plastic tub and got it to spin but not very fast.put everything back together and no spin again.Removed everything again but this time it wouldn't spin at all even if gave it some help.
    What next ??
  • taijoy May 20, 2008
    my double quick 1500 washing maching does not spin. what can i do to fix it
  • Anonymous Jun 19, 2008
    My washer won't spin....when it turns to the spin cycle.
    I have to turn the timer again to try to let it spin.
    sometimes ...it will spin....
    most of the time...I have to try several times to make it spin.
  • Anonymous Aug 18, 2008
    Whirlpool washer will not spin during spin cycle,lid switch is fine,I can get the tub to spin only by starting the tub by hand and after starting the tub by hand I stop the wash machine and tub may start .Motor is running when tub is not. It seems to engage only after i start the tub by hand. Sometimes I have to do this several times before the tub will catch and spin on it's own.When it does catch and spin.it spins dry fine.
  • Anonymous Mar 03, 2009
    My tub is not spinning at all! The first comment posted is exactly what is going on with mine!! I am not sure what to do.....
  • Valley1974 Mar 04, 2009
  • Anonymous Mar 15, 2009
    My whirlpool washer won't drain or spin, what is the problem?
Do you have a direct drive or belt drive washer?
Posted on Nov 13, 2007
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Spin no squeeze
Drain it, unhook it and lay it down, check underneath for broken springs on the drum to the frame
Sep 25, 2012 | Whirlpool Washing Machines
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Washing Machines
My whirpool washer will not spin. Any suggestions?
heatman101 .
Oct 11, 2010 | Whirlpool AWM6140 Front Load Washer
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
My whirpool duel washer agitates or washes but
have you replaced the motor control. i had this happen 1 year ago and had to have it replaced. i am having the same problem and have done some testing but have not found anything else. you can buy this part from whirpool for about $160 delivered to your home. this is exactly how it acted the 1st time it went out. some loads would spin out great and the next load would be wet.
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool washing machine it won't spin after it drains water
Check if there looks like black powder under machine
This would be the coupling falling a part
It is worth fixing and not to hard
The part is under $10
Jun 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine doesn't spin spindel
whirpool part# 80040 agitator dogs need replacing remove center cap remove bolt in agitator pull top section up ..may need to hold bottom down and pull up sharply on top section to separate
Nov 06, 2008 | Roper RAS6233KQ Top Load Washer
The FP code just means that your filter is clogged or has a hair doo-dad or something in it that needs to come out. There are Guys on YouTube that will show you how to do that, step by step, just google Whirlpool AWM8103/1 fault codes to see them. Tip* Have a Large but Shallow pan or container of some sort ready to catch the water that the filter will be holding in it's line because it will come rushing out when you open the filter housing! Towels will be useful. Merry Christmas!
Dec 03, 2017 | Whirlpool AWM8103/1 Front Load Washer
Washer
pull cap off top of agitator remove round cover underneath remove bolt in middle holding agitator down pull agitator up and out pull top portion off by holding bottom half down and pulling top part straight up in center of top part are what are known as agitator dogs either black or tan replace them they are probably worn whirpool part #80040
Aug 28, 2008 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
387 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
