Question about Refrigerators
Whirlpool wbm39 I need to replace thermostat where do I buy one.
Whirlpool accubake oven #GR448LXPB. My oven wont get hot, on any heat setting. It does barrely get warm. Could you tell me what may be the problem
The problem is probably either your thermostat control knob isn't working, may be "gunked" up, or the gas pressure sensor, a long copper thin tube with a larger bulbous attachment at the opposite end, and connected to the oven thermostat INSIDE the range/oven, is either broken or damaged, and can't set your ovens' temperature.
Check to see if the pressure sensor is damaged or broken. If that's the problem, buy another and replace it, being careful to tighten the screws to the thermostat. If that's NOT the problem, then you'll have to take the thermostat OFF, and see if it's got any gunk anywhere that could cause it to malfunction, or take it to a shop that can test it for you, as they are EXPENSIVE to replace.
Dec 06, 2015 | Whirlpool Kitchen Ranges
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
The module of my refrigerator is burnt? So where can buy in the Philippines as part of that? the model of my refrigerator is WBM39 IX. thank you.
Parts & Service
24 D. tuazon St. Cor L. Castillo Quezon City
Telephone No.: (02) 2301555
Fax No.02) 2301510 /2301511
Email Address: service@exatech.com.ph
Oct 09, 2011 | Whirlpool Refrigerators
I have a whirlpool refrigerator model WBM39 1X that the alarm won't stop every time we open the door. The local service people told us that we need to replace the control board. And after two months they...
The best thing to get this annoying fault out of the system assuming that your fridge is other wise working fine, disconnect the line to the buzzer/ alarm. The trigger to the alarm can be due to malfunction of the main board and it may be a false alarm due to failure of some wrong biasing in the circuit. Servicing of the main board may be beyond your limit and it may not be good to tamper and get teh whole thing messed up. hence if you wont mind this , I feel this is the best way to go about with our limitations. Hope this helps. Good day
Jul 22, 2010 | Whirlpool Refrigerators
Whirlpool dryer had been working just fine then suddenly it is not heating at all
** UNPLUG a dryer before attempting ANY repairs. Lethal!
A dryer heater is controlled by the timer, a thermostat and a high-heat safety switch. The thermostat and safety switch are mounted on the housing around the heater.
Most likely - If the heater is blown, a visual inspection inside the heater housing will see a loose heater wire.
Next likely - Thermostat problems occur. I replace the thermostat and high-heat safety if either are suspect. Cheap, easy fix.
Least likely - Controller failure. This can be expensive ($80 - $400) so consider if you want to spend the money. A controller is actually fairly easy to change. Buy a new knob as you are likely to break it without experience and special tools.
Mar 22, 2010 | Whirlpool LER4634J Electric Dryer
Fridge/freezer,wbm39 MS. Motor cuts out after about an hr.
You need someone to open the cover on the compressor and examine or replace the start relay, start capacitor and motor windings. One of those 3 are not working properly.Is the model number you gave made for and sold in the UK? Sea Breeze
May 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge not cooling
Wirlpool wbm39 392LT.
Jan 30, 2009 | Refrigerators
Oven temperature increases 50' after original temperature is reac
What it needs is a new oven thermostat fitting, much cheaper solution than buying a new oven, it is a fairly straight forward repair, if you require more details let me know.
PLz rats my solution.
Thanks.
Jan 03, 2009 | Whirlpool RBS305PDS Electric Single Oven
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
