Question about De'Longhi Dolce gusto Piccolo Single Serve Coffee Maker"
Dolce gusto Hi my machine won't open to put a new pod in, any suggestions? It's been like this a few days and I seriously need a coffee ;-) thanks in advance x
Why i cannot remove the pod of my doce gusto machine
Yahoo Web Search This should help you but you have a ad you need to listen to as well. Thank you and please leave feedback.
Jun 16, 2016 | NESCafe Dolce Gusto Melody II Single Serve...
Red light flashing does not turn to green on dolce gusto piccolo
Same thing just happened to my Dolce Gusto Piccolo. It was off for 2-3 weeks, and after turning on, the light just kept blinking red forever. I tried pulling out water reservoir and putting it back repeatedly for a few dozen times (saw somewhere that air should be pumped out of the system), but It didn't help. Then I plugged out the power cord from the wall socket (while the machine was on), and plugged it back after a few seconds. Turned the Piccolo on, and it worked (blinked red shortly and turned green). Maybe it has something to do with induced current. And maybe pulling the water reservoir actually helped :)
Sep 20, 2013 | Coffee Makers & Espresso Machines
Dolce gusto kp2100 won't stay on
in the machine there is small circuit board that control the machine so they programmed that circuit to preheat the heating element for about 30s if this failed the red light flashes two tims then stops so you have to change the circuit board
Oct 07, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Leaking from pod holder
I had the same exact problem and my machine started to smell even though I descaled it regularly and cleaned any of the milk that dripped out of the capsule. Finally, we took apart the whole machine and found a TON of dried, rotten milk. It was disgusting. We completely cleaned the accessible part of the machine with a vinegar solution and put it back together. I was hoping that we fixed whatever was causing the leaking, but no such luck. It is still leaking and still smells bad, so we are going to get a different kind of machine. I will not be getting a Dolce Gusto again, because I have called their customer service multiple times about this problem, and none of them ever had a solution. The whole milk thing grosses me out, I think I'll just get a single serve coffee machine and foam the milk myself.
Aug 25, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Dolce gusto machine turns itself off
i there why does th machine keep running on once you put the pod in unlike the tassimo once you have the right amount out the pod it cuts off dolce run on for ever and you drjnk ends up wattery
Apr 16, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
My krups dolce gusto stopped working. The lights turn on but nothing happens, no water comes out. I have tried every suggestion there is but nothing has happened..I'm afraid I'll waste money on...
Hi, Could be a number of things. Is your pump working. Thermoblock maybe blocked or faulty. A thermo sensor on the thermoblock maybe faulty. Brewunit maybe jammed. Descale will not help if it wont pump. Id be looking at the thermoblock or sensor. If their at fault then the machine will do nothing. See how you go and ill keep a look out for any more questions you may have. Dazza Repairer
Oct 23, 2011 | Krups Dolce Gusto KP 2100 Espresso Machine
My dolce gusto krups machine won't open and allow me to remove the pod.
We have had this problem twice now. The solution is to drill (yes drill!) through the capsule - a blocked outlet from the capsule itself and the injection of hot water creates a high pressure seal - you have to release the pressure. Do this over the sink - I had hot chocolate spraying about 6 feet from the machine when the pressure was released!! But this solved the problem.
Mar 05, 2011 | Krups Coffee Makers & Espresso Machines
I have a dolce gusto and i am unable to remove the coffee capsule. It seems stuck, as does the lever that punctures the capsule. If the valve lever is moved right or left nothing comes out. Please can you...
I have a dolce gusto and i am unable to remove the coffee capsule. It seems stuck, as does the lever that punctures the capsule. If the valve lever is moved right or left nothing comes out. Please can you help?
Feb 23, 2010 | Krups Coffee Makers & Espresso Machines
De'Longhi Dolce gusto Piccolo Single Serve Coffee Maker" Logo
59 people viewed this question
Top De'Longhi Coffee Makers & Espresso Machines Experts
De Brewerz
De Brewerz
Level 1 Expert
Tom Chichester
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you a De'Longhi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
