Question about Toshiba Satellite L655-S5101 Laptop
Toshiba laptop c655 power light on battery on no fan or no montior
  • 2567 Answers
SOURCE: toshiba laptop a210-15k wont turn
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
  • 8909 Answers
SOURCE: cleaning my fan on my toshiba satellite c655 i
There may be information on this site that will help you;
www.insidemylaptop.com
They specialise in photographing dissasembly of laptops and most Toshiba laptops are put together the same way, so I hope it helps you.
Posted on Feb 04, 2011
  • 693 Answers
SOURCE: Hello, My Toshiba C655-S5195 laptop has
You have a motherboard failure...and will need to replace your motherboard. Sorry to be the bearer of bad news.
Posted on Aug 30, 2011
  • 4961 Answers
SOURCE: why no power in my toshiba laptop C655-S5140
You might need to replace your power cord/charger.
Posted on Jun 30, 2012
  • 6771 Answers
SOURCE: z,/,?,and all four directional keys stopped working on my toshiba satillite c655-5128
The keyboard will more than likely need to be replaced, there are no user servicable parts. Go to www.ebay.com type make and model of laptop, refine search to keyboard.
Posted on Aug 31, 2012
Testimonial: "thanks"
I have a toshiba satellite C655
some laptops will run with out battery and at some point replace it.
Jun 03, 2014 | Toshiba Satellite C655-S5082 Laptop
Toshiba laptop won't power ON
Did you run a bios updateand has an anti virus programme installed? If you did the bios is corrupt and stopping the system from running.
I would remove the RAM and Hard drive. Power up without the battery and look for error messages on the screen. Ensure the RAM is correct and place one strip in at a time.
Nov 25, 2013 | Toshiba Satellite C655-s5090
Toshiba satellite c655 won't power up
Take off the top keyboard and power lid. Check for damage to the power flex cable. Plug in AC adapter. The port where connected power flex cable should have two or three pins. With small screwdriver try two-pin jumper shortly. Does not turn on again? All you need to replace the motherboard
Oct 04, 2013 | Computers & Internet
Toshiba Laptop Satellite C655 will not power up
Take out the battery and only hook up the AC Adapter into a normal working outlet. Push the power button and if it turns on then you know the battery is bad. If you still dont get the laptop to turn on then either you have a bad AC Adapter or the motherboard is bad and would need to be replaced.
Sep 23, 2013 | Toshiba Satellite C655-s5090 Notebook
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Hello there, I own a toshiba c655-s5049 laptop about a year. When I connect a charger taskbar icon shows plugged-in, not charging and the front panel power/battery indicator lights green not orange. When...
Take some alcohol and a q tip and wipe the battery terminals and the terminals on the battery compartment. The laptop not getting a good connection with the battery
Aug 07, 2017 | Toshiba Satellite C655-S5049 Notebook
Cleaning my fan on my toshiba satellite c655 i need to know how to take it apart to get to the fan
Feb 04, 2011 | Toshiba Satellite C655-s5090 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Toshiba Satellite L655-S5101 Laptop Logo
12 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
