Question about Panasonic PT-61DLX75 61" HDTV
Panasonic tv will not turn on. how do i reset the board
Why does my panasonic tc p50st30 tv menu not work, tv will turn on but can not shut it off unless I unplug tv.
I would believe this to be a problem with the lvds cable that goes from your logic board to the main board. If your tv does not have a logic board, then it would have to be incorporated into the main board. A lot of times the connection gets loose on the main to logic board. If you reseat it, it may fix itself. If nothing else, you can pick up a logic board on ebay for around 25 dollars with shipping. It is usually very easy to replace. Most of the time, it's hidden behind the A board known as the Main board. It would probably take less than an hour to put in for someone not familar with the internals of a tv. Just MAKE SURE the tv is NOT plugged into the AC line.
Regards,
Joe Van Buren
Aug 06, 2014 | Panasonic VIERA TC-P50ST30 50-Inch 1080p...
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Jun 20, 2014 | Panasonic "Viera Tc P65 Gt30 65"" Class 3...
Panasonic viera TC-P50G15 tv cut off in the middlde of watching it, red light kept blinking on tv, dont recall how many times, unplugged tv then plugged back in at that point no lights came on & tv...
Tries tv unplug,replug it back like about an hour later,for the tv to a resetting itself back to the factory setting.The tv might work again,if not the tv power supply board is the problems and the causes.The tv power supply board it is shorted and dead some how.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 22, 2011 | Panasonic TC-P50G15 50 in. Plasma HDTV
TV will not turn on. Problem with the Panasonic
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Now the tv should be working again.If still have the same result.Mean ur tv power supply board have problems and the causes.That the board,where the power a/c plug into it.Tries websites like Shojimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jan 19, 2011 | Panasonic TCP42G25 42 in. TV
My panasonic tv won't turn on and the red light just flashes. Any way to fix it?
Tries unplug,replug tv back like about an hour later.By letting the tv resetting itself back to the factory setting.The tv should work again now.But if still have the same problems,the tv power supply board is the problems and the causes.The the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replaement.
Dec 12, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
I turned on power and red light is blinking but tv does not come on - red light just blinking no power/picture Panasonic TC-54PS14
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 06, 2010 | Panasonic TC-54PS14 54" HDTV Plasma TV
My panasonic television blinks a red light three times and then will not turn on. Why is it doing this, and how do i fix it?
Tries the tv unplug,replug it back in like an hour later.The tv now is resetting itself back to the factory setting.The tv now should work.Not,than the tv power supply board is dead.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
When we turn the tv off with the remote, we have to unplug the tv from the wall to reset the tv so that it will turn back on. Once we turn off the tv, it will not power back up with the remote or with the...
The power supply board is the cause.That the board,where the power a/c cord plug into it.Tries website like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Panasonic TCL32X2 32 in. HD-Ready LCD TV
Panasonic PT-61DLX75 61" HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
