Question about Power Acoustik NEW PTID-8920 7" TOUCH SCREEN DVD USB AUX Car Video
I have a power acoustik pt 8920 bt .Screen stays black when you turn it on and no buttons working on the front panel. Can somebody tell me whats the problem?
Yhere is a opening between the screen and the front panel. My 3 yr. old son put a DVD into this opening. In the beginnig it played and everything worked but later i had a black screen and no buttons were working on the front panel. So i decided to take out the DVD. When a tooked it out. it worked for a while but when i put the screen inside and took it out again the screen was black again.
  • 19 Answers
SOURCE: I have a power acoustik bamf 1600/4. not working 5 hours later
use a multimeter to see if the amp has good power wire and remote turn on voltage. then check the ground and make sure its a good strong ground. check the sub to make sure its not bad. make sure it reads whatever ohm its supposed to. anything less than 4 ohms will clip the amp if bridged. if alll that is good then the only thing left is the amp. it sounds like the power supply is bad but check everything else just to make sure. good luck.
Posted on Dec 30, 2009
SOURCE: i have a power acoustik ptid-5850n, It will not play any cd, dvd, mp3, ect., it will not play anything except sd card, usb, and radio???
I HAVE THE SAME PROBLEM WITH MINE CAN SOMEONE
PLEASE HELP THANKS
Posted on Jan 23, 2010
sonicboomele
  • 1557 Answers
SOURCE: Just bought a used Yukon with a Power Acoustik
try putting a laser disc cleaner through the player it will clean the lazer allowing it to read correctly
best of luck
Posted on Dec 28, 2010
dye7
SOURCE: I HAVE A POWER ACOUSTIK PTID-8970NRBT MY PROBLEM MY SCREENSAVER
Here is what I received from Power Acoustik for screensaver and desktop saving from SD card. "You need to have the remote in hand. Insert a memory stick or SD card that has the images you want to use. When the image is displayed, press the pause button on the remote. Then touch the screen to bring up a set of icons on the bottom. If you do not see an icon with a hand, press the arrows that are in a circle until you do. Once you see the hand, press it one time. It will save the image onto the internal memory. You will find the image in the screen tab in settings, under all the stock images."
Posted on Dec 08, 2011
joshia_bell
SOURCE: I have a Power Acoustik
My radio want play CDs or movies it always says disc error
Posted on Jan 07, 2014
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
My power acoustik has a black screen and says no signal
If you have a DVD palying, Press the source button and see if the screen changes.
Aug 04, 2012 | Power Acoustik PT-852CM 8.5 in. Car...
When i turn on my television it acts like it will turn on then the screen stays black. but the power button shows that is on. can anyone tell me what is wrong?
COULD BE A POWER SUPPLY RELATED PROBLEM. FLAT PANEL LCD TVS HAVE POWER SUPPLY FAILURES MOST COMMONLY. COULD BE VENTED CAPACITORS ON THE POWER BOARD OR EVEN CRACKED SOLDER CONNECTIONS.
Dec 17, 2010 | Haier HL46XSL2 46" LCD TV
Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Mar 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic rear projection tv air filter
heres what you do remove front panel "little black door below the screen" get some software cleaner "air" clean all in that box that you just removed the cover from also you might try cue tips and alcohol let dry thoroughly put cover back on and turn on tv it should work if the message comes on again turn the power on and off about 6-10 times and turn back on it should turn on and be fine .if that happens again just open the cover and blow with sopftware clean.sound wierd but after alot of experimenting i fixed my tv that i bought as a salvage because of that error message bhope it works
Feb 19, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Black Box?
my tv was working fine. somebody hit the menu button on the tv or the remote and i get the black box appearing in the middle of the screen. and also the pip is staying on my tv it keeps showing "a snowy picture of pip sjpwomg channels 2 through 18 i cannot figure out how to get this off of my screen.
Feb 08, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Power Acoustik NEW PTID-8920 7" TOUCH SCREEN DVD USB AUX Car Video Logo
22 people viewed this question
Top Power Acoustik Audio Players & Recorders Experts
Ryan Lutton
Ryan Lutton
 Grubhead
Grubhead
richard foulk
Are you a Power Acoustik Audio Player and Recorder Expert? Answer questions, earn points and help others
